Simple error: Debounce.h: No such file or directory But the file exists
Forewarning, I am very new to coding so this is probably incredibly simple.
#include "Debounce.h" // error, No such file or directory
  ButtonInitialize()
  switch(ButtonNextState(digitalRead(4)) {
    case 1:
      Serial.print(1);
    case 2:
      Serial.print(2);
My Debounce.h code is running smoothly, and does in fact have a file, therefore I'm confused as to why the run code is unable to see it
Were is Debounce.h file located on your hard drive and where is the current sketch located?
Please read how to use the forum and correct your post above and add code tags around your code:
[code]`` [color=blue]// your code is here[/color] ``[/code].
It should look like this:// your code is here
(Also press ctrl-T (PC) or cmd-T (Mac) in the IDE before copying to indent your code properly)
