Simple ESP to ESP reading blink program not reading input voltage
One ESP32's 3v3 is connected to GPIO 26 of another ESP32. The program is uploaded. The built-in LED lights for two seconds as expected. Then, it turns off. No matter what GPIO pin the 3v3 is connected to (besides 2), the LED remains off.
 * ON Board LED GPIO 2
#define LED 2
#define inPin 26
  // Pins 34, 35, 36, 39 are input only
  pinMode(LED, OUTPUT);
  // Sanity check LED works
  digitalWrite(LED, HIGH);
  delay(2000);
  Serial.println(digitalRead(inPin));
  digitalWrite(LED, digitalRead(inPin));
Any reason this is happening?
And the GND's of these ESP32's are connected ?
Deva_Rishi:
Yes.
Simply trying to turn LED on/off if external voltage occurs at any GPIO pin (e.g., 26).
I think that the built in led on pin 2 turns on when set LOW.
digitalWrite(LED, !digitalRead(inPin));
cattledog:
It always reads low no matter what.
With that not-statement, it is just always on.
Are you saying that the digitalRead() of the inPin is always LOW even when 3.3V is applied?
cattledog:
Yes.
Where is inPin set as input?
 gpio_config_t io_cfg = {}; // initialize the gpio configuration structure
  io_cfg.mode = GPIO_MODE_INPUT; // set gpio mode. GPIO_NUM_0 input from water level sensor
  io_cfg.pin_bit_mask = ( (1ULL << GPIO_NUM_26)); //bit mask of the pins to set, assign gpio number to be configured
would set pin 26 to input
and
 io_cfg = {};
  io_cfg.mode = GPIO_MODE_OUTPUT;
  io_cfg.pin_bit_mask = ( 1ULL << GPIO_NUM_2 ); //bit mask of the pins to set, assign gpio number to be configured
  gpio_config(&io_cfg);
  gpio_set_level( GPIO_NUM_4, LOW); // deenergize relay module
and this will set gpio 2 as output.
Idahowalker:
Arduino GPIO automatically set as inputs, so I assume the same is true for ESP32.
Cattledog has a good point
  delay(2000);
This switches the output on and turns off the LED straight away. Then it should stay off as-long as you apply 3.3v, and once you ground the pin, the LED should turn 'on' The builtin LED is 'active-low'
Yes it is, but you actually would want to set it INPUT and with have a pulldown resistor, since you want to test if it responds to 3.3v
Very confused now.
I put
pinMode(26, INPUT_PULLUP);
in setup(). Always "1" or high now.
adamelli:
Very confused now.
I put
Until you connect the pin to GND.
adamelli:
I've not read that in the ESP32 API.
Idahowalker:
I’ve not read that in the ESP32 API.
That was it. Thanks.
#define LED 2 // ON Board LED GPIO 2
#define inPin 26
  pinMode(inPin, INPUT); // <----------
