simple FACEBOOK LIKE COUNTER
Hello everyone!
First things first I’m a newby with arduino so please dont be uppset if I ask trivial questions.
As my first project I decided to make a really simple fb like counter, but it seems I stucked on the verry beginning.
The thing that I would like to read the answer of the following get request:
https://graph.facebook.com/shapenbake2018?access_token=EAAFBCZCd1lKoBABihTZCsWOvWHgX8qIWbO0TSxrwJAriYFgdZA0NKOtrcecQcMH0grb5UF9RKVsHKVbC4IeoR25ZBCEZCN8Qckn8VkbvKNr5HwqhqTzkOBHCBXe3YydUWOrVf9XbIuOjUYCTv87w2IVxwHeDLPZBP3bjovwvcL64OGy59JwQ7NSAiXpnSTk8ZCaSIW5XSEJDgZDZD&fields=fan_count
But the terminal answer seems to shows nothing or only a single carachter from the results.
Can somebody give me any advice where my code wrong and what should i do to be able to write fan_caunt value on terminal?
Thank you for your prompt answer and help! Happy New Year!!
Below I leave here the terminal result and my source
—TERMINAL—
17:07:05.628 → Connecting to UPC4191181
17:07:06.248 → …
17:07:10.037 → WiFi connected
17:07:10.037 → IP address:
17:07:15.055 → connecting to graph.facebook.com
17:07:20.127 → 2
— SOURCE —
#include <ESP8266WiFi.h>
const char* ssid     = "UPC4191181"; //Wi-Fi SSID
const char* password = "UYGRXZZG"; //Wi-Fi Password
//Only used if using Static IP
IPAddress ip(192, 168, 0, 6); //IP
IPAddress gatewayDNS(192, 168, 0, 1);//DNS and Gewateway
IPAddress netmask(255, 255, 255,0); //Netmask
//Server IP or domain name
const char* host = "graph.facebook.com";
  delay(10);
  // We start by connecting to a WiFi network
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.config(ip,gatewayDNS,netmask,gatewayDNS); //Only used if using Static IP
  WiFi.begin(ssid, password); //Connecting to the network
  while (WiFi.status() != WL_CONNECTED) { //Wait till connects
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
  //Serial.println(WiFi.localIP()); //Use if using DHCP to know the IP
  delay(5000);
  Serial.print("connecting to ");
  Serial.println(host);
  WiFiClient client; //Client to handle TCP Connection
  const int httpPort = 443;
  if (!client.connect(host, httpPort)) { //Connect to server using port httpPort
    Serial.println("connection failed");
    return;
  // We now create a URI for the request
  String url = "/shapenbake2018?access_token=EAAFBCZCd1lKoBABihTZCsWOvWHgX8qIWbO0TSxrwJAriYFgdZA0NKOtrcecQcMH0grb5UF9RKVsHKVbC4IeoR25ZBCEZCN8Qckn8VkbvKNr5HwqhqTzkOBHCBXe3YydUWOrVf9XbIuOjUYCTv87w2IVxwHeDLPZBP3bjovwvcL64OGy59JwQ7NSAiXpnSTk8ZCaSIW5XSEJDgZDZD&fields=fan_count"; //File or Server page you want to communicate with. along with data
  // This will send the request to the server
  client.print(String("GET ") + url + " HTTP/1.1\r\n" +
               "Host: " + host + "\r\n" +
               "Connection: close\r\n\r\n");
  unsigned long timeout = millis();
  while (client.available() == 0) {
    if (millis() - timeout > 25000) { //Try to fetch response for 25 seconds
      Serial.println(">>> Client Timeout !");
      client.stop();
      return;
  // Read all the lines of the reply from server and print them to Serial
  while(client.available()){
    String line = client.readStringUntil('\r');
    Serial.print(line);
  Serial.println("closing connection");
  client.stop(); //Close Connection
You should try the HTTPClient library. It will make it easier. It looks like the response is JSON so you could either parse it directly (it's pretty trivial) or use a JSON library.
Thank you so much!
It was a great idea, I allready made it work.
Now im trying to make the url by combining variables.
    fb_url = "https://graph.facebook.com/" + fb_pagename + "?access_token=" + fb_accesstoken + "&fields=fan_count";
all of my variables are const char* type and I’m getting the following error.
Could you help with it too?
invalid operands of types ‘const char [28]’ and ‘const char*’ to binary ‘operator+’
Answer already provided here. Please don't cross post, it's a waste of effort.
