Simple fade transition
I am trying to create a simple transitional fade effect when I turn an LED on/off. I have been at it for days and can’t figure out how to do it. I have a sensor and when someone steps into a certain range, I want the LED to FADE ON and stay ON. When he/she walks out of that range I want the LED to FADE OFF and stay OFF. I do not what the light to oscillate when it is on or off, just fixed status…
it is just a simple transitional effect…
int SensorPin = A0;
#define ledPin 9
pinMode(9, OUTPUT);
pinMode(SensorPin, INPUT);
int val = analogRead(SensorPin);
if (val >= 150) // pre-defined distance i am using
{digitalWrite(9, HIGH);} // At this point I want the LED to FADE ON
else if (val <= 170) // pre-defined distance i am using
{digitalWrite(9, LOW);} // At this point I want the LED to FADE OFF
Serial.print(val);
Serial.println(" ");}
Did you try Fade Example code?
int SensorPin = A0;
#define ledPin 9
  pinMode(9, OUTPUT);
   {for(int fadeValue = 0 ; fadeValue <= 255; fadeValue +=5) {
    // sets the value (range from 0 to 255):
    analogWrite(ledPin, fadeValue);
    // wait for 30 milliseconds to see the dimming effect
    delay(30);
  { for(int fadeValue = 255 ; fadeValue >= 0; fadeValue -=5) {
    delay(30);
Serial.print(val);
I did... I don't want it to pulse. It is just a simple transition effect. I want it to fade from off to on and then stay on when someone is in range. When he/she moves. it fades off...
check out this similar post.
The last post you had was close.
this video is essentially what i want.. when the sensor is triggered it gradually comes on. when you walk of range, the light gradually shuts off... https://www.youtube.com/watch?v=A-EEppHIzxs
I would like to do this with the arduino rather than building the circuit..
so try the example I provided and play with the delay(10) to something like delay(20) in the two functions like this:
you have to experiment with it and see what you get…
int SensorPin = A0;
int ledPin = 9;
int oldVal;
  pinMode(9, OUTPUT);
  if (val <= 150 && oldVal > 150)//<<<<<<<<<<<<
    fadeUp();
  else if (val >= 170  && oldVal < 170)//<<<<<<<<<<
    fadeDown();
  oldVal = val;
void fadeUp()
  for (int i = 0; i <= 255; i++)
    analogWrite(ledPin, i);
    delay(20);
void fadeDown()
    analogWrite(ledPin, 255 - i);
    delay(20);
the lights are on when they should be off and they are still pulsing. also, the sequence is also backwards.. I tried flipping the fadeUp and fadeDown int's you built and that doesn't fix it.
