Simple flash
Hello All
i want to have LED 1 flash for one second turn off for one second then LED 2 come on for a second and turn off for a second.....and loop, eventually leading to a poor mans multiplexing. I cant seem to get working, what happens is they both come on for one second and off for two.
please advise.....thanks
  // initialize the digital pin as an output.
  pinMode(13, OUTPUT);
  pinMode(12, OUTPUT);
  digitalWrite(13, HIGH);   // set the LED1 on
  delay(1000);              // wait for a second
  digitalWrite(13, LOW);    // set the LED1 off
  digitalWrite(12, HIGH);   // set the LED2 on
  digitalWrite(12, LOW);    // set the LED2 off
Do you want LED2 to come on right after LED1 goes off?
the end result will be using this code to multiplex a 8x8 RGB, i had it hooked up to said matrix and the effect was described above, however I disconnected the circuit and hooked up only two LEDs and the code worked!!!
any thoughts?
It all depends on if the matrix was hooked up correctly. Do you have a schematic of your setup?
http://www.robotshop.com/ca/content/PDF/2088rgbmatrix-led204a5b.pdf
do you have a schematic of how and what was hooked to your board?
