Hmm, Atmel parametric table says '328P has 16 touch channels.
I don't know anything about them outside of this:
6. Capacitive Touch Sensing
The Atmel® QTouch® Library provides a simple to use solution to realize touch sensitive interfaces on most Atmel AVR® microcontrollers. The QTouch Library includes support for the Atmel QTouch and Atmel QMatrix® acquisition methods.
Touch sensing can be added to any application by linking the appropriate Atmel QTouch Library for the AVR Microcontroller. This is done by using a simple set of APIs to define the touch channels and sensors, and then calling the touch sensing API’s to retrieve the channel information and determine the touch sensor states.
The QTouch Library is FREE and downloadable from the Atmel website at the following location:
www.atmel.com/qtouchlibrary. For implementation details and other information, refer to the Atmel QTouch Library User Guide - also available for download from Atmel website."
"Capacitive Touch
Atmel QTouch® Library makes it simple for developers to embed capacitive-touch button, slider, and wheel functionality into general-purpose AVR microcontroller applications. The royalty-free QTouch Library provides several library files for each device and supports different numbers of touch channels, enabling both flexibility and efficiency in touch applications. By selecting the library file supporting the exact number of channels needed, developers can achieve a more compact and efficient code using less RAM."
You can use the parameter search here to see what chips might offer more. Use the Show/Hide feature to add Q-touch channels to the display, and hide some of the other stuff.
http://www.atmel.com/v2PFResults.aspx#(actives:!(8238,8394,8362,8282,8431,8300,8358,8392,8378,8445,8236,8449,8474,8248,8264,8447,8256,8254,8286,8462,8429,8458,8466,8400,8302,8278,8327),data:(area:'',category:'34864[33180]',pm:!((i:8238,v:!(1,16)),(i:8394,v:!(0,14)),(i:8362,v:!(2,27)),(i:8282,v:!(4)),(i:8431,v:!(1,33)),(i:8300,v:!(1,8)),(i:8358,v:!(1,64)),(i:8392,v:!(0,1)),(i:8378,v:!n),(i:8445,v:!(0,3,4,5,6,8)),(i:8236,v:!(0,24)),(i:8449,v:!(1,10)),(i:8474,v:!(0)),(i:8248,v:!(0,1)),(i:8264,v:!(1,5)),(i:8447,v:!(0,1)),(i:8256,v:!(1,2,4)),(i:8254,v:!(3,15)),(i:8286,v:!(0,3)),(i:8462,v:!(0,8)),(i:8429,v:!(1,10)),(i:8458,v:!(0,4)),(i:8466,v:!(1,2,4)),(i:8400,v:!(0,20)),(i:8302,v:!(0,1)),(i:8278,v:!(0,1,2)),(i:8327,v:!n)),view:list),sc:1)
