Hi!! I dont know how to program... and I used the base of the grame from:
https://forum.arduino.cc/index.php?topic=516532.0
but I can not replay that topic.
So I have updated the code..
In this game you have to input the correct number shown in binary (from 1 to 15) in 10 seconds.
Its working... ok.... but is not very random.... each time y restart the arduino it will start the same sequence of numbers.
Thanks again to the original developer
DanielBnl
#include <TimerOne.h> // De TimerOne library wordt gebruikt
#include <Wire.h> // De Wire library wordt gebruikt
#include <MultiFuncShield.h> // De MultiFuncShield library wordt gebruikt
int number = 0;
const int ledPin1 = 10; //Declaratie van de LED die op pin 10 aangesloten is
const int ledPin2 = 11; //Declaratie van de LED die op pin 10 aangesloten
const int ledPin3 = 12; //Declaratie van de LED die op pin 10 aangesloten
const int ledPin4 = 13; //Declaratie van de LED die op pin 10 aangesloten
const int buttonPin = A1; //Declaratie van de buttonPin
/* Define shift register pins used for seven segment display */
#define LATCH_DIO 4
#define CLK_DIO 7
#define DATA_DIO 8
/* Segment byte maps for numbers 0 to 9 */
const byte SEGMENT_MAP[] = {0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0X80,0X90};
/* Byte maps to select digit 1 to 4 */
const byte SEGMENT_SELECT[] = {0xF1,0xF2,0xF4,0xF8};
unsigned long Cur_ms_Count; // Stores the current time in ms
unsigned long Last_ms_Count; // Stores the last time in ms the counter was last updated
int Count; // Stores the value that will be displayed
//array van alle karakters dat in hexadecimaal past
char hexDigits[] = {'0', '1', '2', '3', '4', '5', '6', '7', '8', '9', 'a', 'b', 'c', 'd', 'e', 'f'};
int buttonState = 0;
int prevButtonState = 0;
int counting = 0;
int countTime = 10; // tiempo para responder
int HighScore = 0; // Puntaje
long startTime;
long InicioCuentaRegresiva;
byte hasError;
void printNumber(int number) {
Serial.println("--------------------------");
Serial.print("Random number: ");
Serial.print(number);
void convertToBinary(byte number, int binary[4]) {
for (int i = 0; i <= 3; i++) {
if (bitRead(number, i) == 1) {
binary[i] = 0;
else {
binary[i] = 1;
void displayBinary(byte number) {
int binary[4];
convertToBinary(number, binary);
digitalWrite(ledPin1, binary[0]);
digitalWrite(ledPin2, binary[1]);
digitalWrite(ledPin3, binary[2]);
digitalWrite(ledPin4, binary[3]);
void WriteNumberToDigit(byte digit, byte Value)
digitalWrite(LATCH_DIO,LOW);
shiftOut(DATA_DIO, CLK_DIO, MSBFIRST, SEGMENT_MAP[Value]);
shiftOut(DATA_DIO, CLK_DIO, MSBFIRST, SEGMENT_SELECT[digit] );
digitalWrite(LATCH_DIO,HIGH);
/* Set DIO pins to outputs */
pinMode(LATCH_DIO,OUTPUT);
pinMode(CLK_DIO,OUTPUT);
pinMode(DATA_DIO,OUTPUT);
Timer1.initialize();
MFS.initialize(); // initialiseert the Multi Function Display en de Timer1 bibliotheek
Serial.begin(9600); // initialiseert de seriële monitor
randomSeed(analogRead(0));
InicioCuentaRegresiva = millis();
number = random(1, 16); // genereert willekeurige cijfers van 1 tot en met 15
hasError = 0;
startTime = millis();
printNumber(number);
displayBinary(number);
pinMode(ledPin1, OUTPUT); // declareert LED D4 als output
pinMode(ledPin2, OUTPUT); // declareert LED D3 als output
pinMode(ledPin3, OUTPUT); // declareert LED D2 als output
pinMode(ledPin4, OUTPUT); // declareert LED D1 als output
pinMode(buttonPin, INPUT); // declareert pushbutton S1 als output
void reset() {
hasError = 0;
counting=0;
countTime=10;
byte btn = MFS.getButton();
buttonState = digitalRead(buttonPin);
if (millis() - InicioCuentaRegresiva > 1000) {
WriteNumberToDigit(0 , countTime);
countTime--;
InicioCuentaRegresiva = millis() ;
if (countTime <= 0 ) {
MFS.write("LOSE") ;
HighScore=0;
while (!MFS.getButton()) {
delay(100);
reset();
if (btn == BUTTON_1_SHORT_RELEASE )
counting++;
if ( counting > 15 )
counting = 15;
MFS.write(counting);
if (btn == BUTTON_2_SHORT_RELEASE )
counting--;
if ( counting < 0 )
counting = 0;
if (btn == BUTTON_3_SHORT_RELEASE )
// Check click numbers
if (counting == number ) {
HighScore++;
MFS.write(HighScore) ;
reset();
MFS.write("LOSE") ;
HighScore = 0;
reset();
