Hello,
I am very new to Arduino coding and I am trying to write some code that would require me to use a wire to create a simple switch. My wire is connected to the ground and to digital pin 2. When I pull the wire out of the pin, I want my code to print out "Off", which would signify that my set up should not be running and my value is 0 volts as opposed to 5v when it is connected to pin 2. The goal is to have the wire act as a switch without needing a button or resistor. I am a bit confused, though I assume it is a simple task. Here is what I have so far, which does not work. (Pin 13 is not connected to anything)
Wire.begin();
pinMode(2, INPUT_PULLUP);
pinMode(13, OUTPUT);
int sensorVal = digitalRead(2);
Serial.println(sensorVal);
if (sensorVal == HIGH) {
digitalWrite(2, LOW);
digitalWrite(2,HIGH);
Thank you in advance!
Why are you reading from pin 2 and then writing to pin 2 ?
Whoops, sorry I had it to pin 13 in my actual code.
So let's see your actual code in a new post, but please Read this before posting a programming question and follow the recommendations regarding posting code
1. The following diagram (Fig-1) shows the Internal Pull-up associated with DPin-2 and the external jumper wire.
Figure-1:
2. When the internal pullup is connected and the jumper is also connected, the logic level at DPin-2 is LOW (0V)
bool n = digitalRead(2); // n = LOW ~= 0V
3. When the internal pullip is connectec and the external jumper is renoved, the logic level of DPin-2 is HIGH (5V).
bool n = digitalRead(2); // n = HIGH ~= 5V
4. Composite Code
if (n == LOW)
Serial.print("Jumper is connected");
else //n == HIGH
Serial.print("Jumper is disconnected");
Your program all sounds very complex for what is a simple routine. You don't need any libraries, WIRE is for sensors using the "one wire" protocol, not switches.
Input pullup is fine, that will give a logical high when the wire is removed.
All you need to do is look at the state of D2 with digitalRead and then print when the input reads logical low.
