Simple Interrupt
I have a RFID Reader/Writer module that I am attempting to read the ID number of a transponder tag with.
When a valid transponder is seen by the RFID module, an output is pulled LOW.
I have this output connected to Pin 10 of the Arduino UNO.
When Pin 10 goes low, I must send a "read" command to the module.
My question is:
How do I constantly monitor Pin 10 to establish its state (High/Low)
If I use Pin 2 the interrupt on the ATMEGA328, how would I implement this?
Many Thanks
For how long?
What else is the Arduino doing? Polling may be enough, depending on how often you poll and how long the pin is LOW.
The usual way? Use attachInterrupt to define what function to be called when the pin is FALLING to LOW.
In that function, be fast - no serial input/output, no delay()s.
robcole:
I have this output connected to Pin 10 ... If I use Pin 2 the interrupt on the ATMEGA328, how would I implement this?
Connect the output to pin 2?
robcole:
Which module? Link to datasheet?
The module I am using is RWD-QT datasheet: http://www.ibtechnology.co.uk/pdf/RWD_QT.PDF
