Simple IR to RS232 (w RS232 shield) unstable
Hey guys, this is my first post, so be gentle :o
As of right now i cant paste my code; but anyway I have a simple Arduino UNO setup, with an IR Sensor (came with kit) and a RS232 shield attached.
My loop code basically listens for IR hex codes; and has several "case" arguments for sending a different ASCII string for each of the different IR codes from my remote.
It WORKS, BUT;
  • Just as i have uploaded my code to the Arduino, the LED's indicate that every single command is recieved, and the TX led of my RS232 board signals sending. All perfect.
But when i just power my arduino with a USB A-B cable and a wall outlet, it only seems to listen to IR/ send these commands every now and then.
Could someone please write me an example code that should work? (Ex ACSII string that i send is "[DEVIALET>POWER=1]")
Bless, and best wishes from Norway.
I will post my code later today :slight_smile:
What RS232 shield?
Can you post links to specs/data.
Without code or circuit we cannot really offer any solutions.
Tom... :slight_smile:
kristianskauge:
Smells like you forgot a Gnd connection somewhere.
Here is the Code im using.
Im not good at this at all.. so. Can anyone spot anything that will cause this to work only sporadically?
Thanks!
// Include IR Remote Library by Ken Shirriff
#include <IRremote.h>
#include <SoftwareSerial.h>
// Define myserial RX & TX
// SoftwareSerial mySerial(10, 11); // RX, TX
// Define TX pin
const int tx = 1;
// Define RX pin
const int rx = 0;
// Define sensor pin
const int RECV_PIN = 4;
// Define LED pin constants
const int redPin = 8;
// Define integer to remember toggle state
int togglestate = 0;
// Define IR Receiver and Results Objects
IRrecv irrecv(RECV_PIN);
decode_results results;
// Lagrer forrige IR-kode mottatt
// unsigned long lastCode;
void setup(){
 // Enable the IR Receiver
 irrecv.enableIRIn();
 // Set LED pins as Outputs
//  pinMode(redPin, OUTPUT);
 //start the serial communication
//   mySerial.begin(115200);
void loop(){
   if (irrecv.decode(&results)){
   //      if(results.value == 0xFFFFFFFF)   // if repeat command (button held down)
   //   results.value = lastCode;      // replace FFFF with last good code
       switch(results.value){
         case 0xFD00FF: //POWER KNAPP
       // lastCode = results.value;     // registrer koden for gjentakelse
       // mySerial.print("[DEVIALET>POWER=1]");
       Serial.println("[DEVIALET>POWER=1]");
         case 0xFD40BF: //FUNC/STOP KNAPP
       // mySerial.print("[DEVIALET>POWER=0]");
       Serial.println("[DEVIALET>POWER=0]");
         case 0xFD807F: //VOL+ KNAPP
       // mySerial.print("[DEVIALET>VOLUME=++]");
       Serial.println("[DEVIALET>VOLUME=++]");
          case 0xFD906F: //VOL- KNAPP
       // mySerial.print("[DEVIALET>VOLUME=--]");
       Serial.println("[DEVIALET>VOLUME=--]");
          case 0xFD20DF: //PREV-KNAPP
       // mySerial.print("[DEVIALET>SOURCE=--]");
       Serial.println("[DEVIALET>SOURCE=--]");
          case 0xFD609F: //NEXT-KNAPP
       // mySerial.print("[DEVIALET>SOURCE=++]");
       Serial.println("[DEVIALET>SOURCE=++]");
          case 0xFDA05F: //PLAY/PAUSE
       // mySerial.print("[DEVIALET>MUTE=!]");
       Serial.println("[DEVIALET>MUTE=!]");
       delay(200);
          case 0xFD30CF: //0-knapp
       // mySerial.print("[DEVIALET>SOURCE=USB]");
       Serial.println("[DEVIALET>SOURCE=USB]");
          case 0xFD08F7: //1-knapp
       // mySerial.print("[DEVIALET>SOURCE=Optical1]");
       Serial.println("[DEVIALET>SOURCE=Opt 1]");
       delay(200);
       Serial.println("[DEVIALET>SOURCE=Optical1]");
          case 0xFD8877: //2-knapp
       // mySerial.print("[DEVIALET>SOURCE=Opt 2]");
       Serial.println("[DEVIALET>SOURCE=Optical 2]");
          case 0xFD48B7: //3-knapp
       // mySerial.print("[DEVIALET>SOURCE=Line 1]");
       Serial.println("[DEVIALET>SOURCE=Line 1]");
          case 0xFD28D7: //4-knapp
       // mySerial.print("[DEVIALET>SOURCE=Line 2]");
       Serial.println("[DEVIALET>SOURCE=Line 2]");
          case 0xFD50AF: //OPP-knapp
       // mySerial.print("[DEVIALET>SAM=1]");
       Serial.println("[DEVIALET>SAM=1]");
          case 0xFD10EF: //NED-knapp
       // Turn on LED for 20Ms
       // digitalWrite(redPin, LOW);
       // delay(200);
       // digitalWrite(redPin, HIGH);
       // mySerial.print("[DEVIALET>SAM=0]");
       Serial.println("[DEVIALET>SAM=0]");
   irrecv.resume();
DrDiettrich:
Hmm..
Im pretty sure both the IR reciever and the TX/RX/GND part of the RS232 board is connected properly. Would it work otherwise?..
Kriss
http://forum.arduino.cc/index.php/topic,148850.0.html then look down to item #7 about how to post your code.
It will be formatted in a scrolling window that makes it easier to read.
I only can see Serial.print() in your code. So is the RS232 board connected to RX/TX? And also to Gnd?
What if you reduce the baudrate, to make the LED blink longer on a transmission?
TomGeorge:
Thanks. Fixed the code entry in my post now :slight_smile:
Here are some pictures of my setup. I connect RX - TX - and GND Pins to the product Im controlling
DrDiettrich:
RS232 Board connect to default rx-tx pins, yes, and ground i presume. I can try to lower the baudrate. However the product im controlling has baud-rate selection, and is set to the same as in the code
PS: My RS232 board has a switch for enabling/disabling the board, to not stop uploading the code to the Arduino UNO
I suggested the reduced baud rate only for visual inspection of the LED.
What happens if you disconnect the external device, and only switch the power source?
DrDiettrich:
You mean powering it with my powersource, but not connecting the TX-RX-GND to the end product?
Thanks for helping :slight_smile: <3
This is possibly the schematic of your shield.
Tom.. :slight_smile:
TomGeorge:
Thanks! (As if I'm good at reading these schematics :D)
Could my trouble be GND related, in as some error in not having common ground between the powersource/Arduino/IR Reciever/End product that i control w 232?
I really have no clue what to do to fix this. It's what i got the Arduino for
