Maybe your experience can help me with something realy odd. I try to create led(s) that blink in an infinite loop. But for some reason the led loop stops and kind of starts again from "beginning".
Can you help me to solve this loop failure?
I have recorded the behavior:
Here's the code:
int redPin = 2; // Red LED connected to digital pin 12
int greenPin = 3; // Green LED connected to digital pin 11
void setup() // run once, when the sketch starts
pinMode(redPin, OUTPUT); // sets the digital pin as output
pinMode(greenPin, OUTPUT); // sets the digital pin as output
void loop() // run over and over again
digitalWrite(redPin, HIGH); // sets the Red LED on
digitalWrite(greenPin, HIGH); // sets the Green LED on
delay(500); // waits for half a second
digitalWrite(redPin, LOW); // sets the Red LED off
digitalWrite(greenPin, LOW); // sets the Green LED off
It does not matter how many leds i try to blink, Arduino always gets interrupted by something...
I am using newest Arduino SW and an old Duemilanove board.
Do you have something else wired with either pin2 or pin3?
Repeat your test with some other pins, say 4 and 5.
If the problem still exists, replace the arduino and see what happens then.
Does the reset come always after a "repeatable" time or without pattern?
If so, then check your power supply (USB cable from PC?) and repeat the test with a DC adapter.
Wow, I didn't expect such fast help from forum members
Thanks.
The serial.print trick is a good advice. I added it to the code. It seems that the code/LEDs started to work immediately after my posting. I strongly believe that I have some kind of loose connection which resets the board
walter_v:
What 'failure'? The program does exactly(!) what you have programmed.
Two times delay(500); in the loop means that the loop() roughly restarts after one second.
So what do you expect the code to do?
Add together all the delay() used within loop and you will know when loop() will restart!
walter_v: @jurs: Yeah, but the loop should not be interrupted like in the video. I.e. a constant running blink...
Yeah, but also the comments in the code seem to be wrong.
Perhhaps much more than the comments (or pin numbers) is wrong, I don't know, insufficient information.
Besides of that I don't see about current limiting resistors and circuit schematics diagram.
