climbing the steep learning curve of electronics...
In a simple LED circuit, is the position of the resistance important. ie, is:
Battery + ---- LED --- resistor --- ground
the same as
Battery + ---- resistor --- LED --- ground
I would say it's exactly the same, and I could even replace the LED with a laser module and it would still be the same - it's not important where the resistor is. But am I right?
Yes, you are right. The order of the LED and resistor is unimportant. Sometimes, when we’re dealing with multiple LEDs in one package (7-segment, etc.), then all the LEDs are joined together at one end, on a single pin. In that case, we must fit one resistor on each LED, on the end that’s not all connected together. But for individual LEDs, it doesn’t matter.
One thing to consider if the LED is connected to the rest of the circuit by long wires is what might happen if one of the connecting leads shorts to something else (usually ground is exposed).
The Bat+ ==> resistor ==> LED ==> Gnd arrangement is unlikely to suffer damage if either of the LED leads shorts to gnd
However in the
Bat+ ==> LED ==> resistor ==> Gnd arrangement shorting one of the LED's connecting wires to GND may damage the power supply and shorting the other will almost certainly blow the led.
