Simple loop problem
I am just starting out with Arduino and am working my way through the examples in the Franzis Tutorial Kit but I an unable to get a simple loop working correctly. I have written a simple sketch to test it out and I get same problem as using the example in the book.
I want to output the values in an array using a for loop with the variable increment of 1 until it reaches the limit, however I don’t get what I expect. I have output each variable in the array manually and they are correct so it is a problem with the for loop.
My code is below
int Array[]={1,2,3,9,5};
Serial.println("Test");
     byte y;
    Serial.println("Output test");
    for (y=0;y<4;y++);
      Serial.println(Array[y]);
      //Serial.println(Array[0]);
      //Serial.println(Array[1]);
      //Serial.println(Array[2]);
      //Serial.println(Array[3]);
      //Serial.println(Array[4]);
    while(1);
The output looks like this:
Test
Output test
5
Any ideas gratefully received.
    for (y=0;y<4;y++);
for statements don’t generally end with a ;.
That fixed it - thanks!
