Hello !,
I think I'm missing something here despite mapping and the value being in the mapping range it still outputs it as an unmapped value. ![]()
I looked at the syntax and usage of map in other codes and don't know why it doesn't work here.
I think I'm just missing something obvious.
Thanks in advance! ![]()
Here the Code: (the Code is still extremely inefficient)
#include <Wire.h>
#include <Servo.h>
int lepos = 0;
int leposdue = 0;
#define PWM_PIN 8
unsigned int pwm_value;
Servo azimuth9;
Servo elevation12;
const byte numChars = 16;
char receivedChars[numChars]; // an array to store the received data
boolean newData = false;
float azimuth;
float elevation;
const int MPU_addr=0x68; int16_t AcX,AcY,AcZ,Tmp,GyX,GyY,GyZ;
int minVal=265; int maxVal=402;
double x; double y; double z;
//-------------------------------SETUP-----------------------------------
pinMode(PWM_PIN, INPUT);
int lepos = 0;
Wire.begin(); Wire.beginTransmission(MPU_addr); Wire.write(0x6B);
Wire.write(0); Wire.endTransmission(true); Serial.begin(9600);
azimuth9.attach(9);
elevation12.attach(12);
azimuth9.write(0);
elevation12.write(0);
delay(2000);
Serial.println("<Arduino is ready> Enter Azimuth and Elevation separated with a semicolon (;) ");
//-------------------------------LOOP-----------------------------------
// delay(50);
//--------------- PITCH ------------------------------------------------------------
if(y > elevation)
{lepos--;
elevation12.write(lepos);
else{}
lepos = constrain(lepos, 0, 180);
if(y < elevation)
{lepos++;
elevation12.write(lepos);}
else{}
pwm_value = pulseIn(PWM_PIN, HIGH);
map(pwm_value, 9863, 29532, 0, 360);
Serial.print("PWM:");
Serial.println(pwm_value);
if(pwm_value > azimuth)
{leposdue--;
azimuth9.write(leposdue);
else{}
leposdue = constrain(leposdue, 0, 180);
if(pwm_value < azimuth)
{leposdue++;
azimuth9.write(leposdue);}
else{}
Serial.print("leposdue :");
Serial.println(leposdue);
Serial.print("lepos ");
Serial.println(lepos);
Serial.print("elevation ");
Serial.println(elevation);
Serial.print("y ");
Serial.println(y);
Wire.write(0x3B); Wire.endTransmission(false); Wire.requestFrom(MPU_addr,14,true);
AcX=Wire.read()<<8|Wire.read(); AcY=Wire.read()<<8|Wire.read(); AcZ=Wire.read()<<8|Wire.read();
int xAng = map(AcX,minVal,maxVal,-90,90); int yAng = map(AcY,minVal,maxVal,-90,90);
int zAng = map(AcZ,minVal,maxVal,-90,90);
x= RAD_TO_DEG * (atan2(-yAng, -zAng)+PI); y= RAD_TO_DEG * (atan2(-xAng, -zAng)+PI); z= RAD_TO_DEG * (atan2(-yAng, -xAng)+PI);
y= constrain(y, 0, 180);
recvWithEndMarker();
//showNewData();
if (newData)
parseData();
void recvWithEndMarker()
static byte ndx = 0;
char endMarker = '\n';
char rc;
while (Serial.available() > 0 && newData == false)
rc = Serial.read();
if (rc != endMarker)
receivedChars[ndx] = rc;
ndx++;
if (ndx >= numChars)
ndx = numChars - 1;
receivedChars[ndx] = '\0'; // terminate the string
ndx = 0;
newData = true;
void showNewData()
if (newData == true)
Serial.print("This just in ... ");
Serial.println(receivedChars);
//newData = false;
void parseData()
char *strings[16]; // an array of pointers to the pieces of the above array after strtok()
char *ptr = NULL; byte index = 0;
ptr = strtok(receivedChars, ";"); // delimiters, semicolon
while (ptr != NULL)
strings[index] = ptr;
index++;
ptr = strtok(NULL, ",");
//Serial.println(index);
// print all the parts
/*Serial.println("The Pieces separated by strtok()");
for (int n = 0; n < index; n++)
Serial.print("piece ");
Serial.print(n);
Serial.print(" = ");
Serial.println(strings[n]);
// convert string data to float numbers
azimuth = atof(strings[0]);
elevation = atof(strings[1]);
newData = false;
Serial.print("Azimuth = ");
Serial.print(azimuth, 3);
Serial.print(" Elevation = ");
Serial.println(elevation, 3);
Serial.println(); // blank line
