BobbyKay:
Hi There,
I've done a simple sketch where if you enter a single digit in the serial monitor, it multiplies that number by 2. Here is the code:
You are supposed to do this with code, as told in the read me before posting thread at the top of the forum.
Here's the address to cut&paste:
https://forum.arduino.cc/index.php?topic=148996.0
int number;
number = 0;
Serial.flush();
while (Serial.available() == 0)
while (Serial.available() > 0)
number = Serial.read() - '0'; //read the number in the serial buffer and remove ASCII text offset for zero: '0'
Serial.print("You entered: ");
Serial.println(number);
Serial.print(number);
Serial.print(" multiplied by two is ");
number = number * 2;
Nick Gammon has a state machine tutorial about 1/3rd down the page here: Gammon Forum : Electronics : Microprocessors : How to process incoming serial data without blocking
There is a lot of explanation on the site, line-by-line of the code below.
This code reads letter-number combination commands and only accepts valid input. It does that without blocking or buffering.
// Example state machine reading serial input
// Author: Nick Gammon
// Date: 17 December 2011
// the possible states of the state-machine
typedef enum { NONE, GOT_R, GOT_S, GOT_G } states;
// current state-machine state
states state = NONE;
// current partial number
unsigned int currentValue;
void setup ()
Serial.begin (115200);
state = NONE;
} // end of setup
void processRPM (const unsigned int value)
// do something with RPM
Serial.print ("RPM = ");
Serial.println (value);
} // end of processRPM
void processSpeed (const unsigned int value)
// do something with speed
Serial.print ("Speed = ");
} // end of processSpeed
void processGear (const unsigned int value)
// do something with gear
Serial.print ("Gear = ");
} // end of processGear
void handlePreviousState ()
switch (state)
case GOT_R:
processRPM (currentValue);
case GOT_S:
processSpeed (currentValue);
case GOT_G:
processGear (currentValue);
} // end of switch
currentValue = 0;
} // end of handlePreviousState
void processIncomingByte (const byte c)
if (isdigit (c))
currentValue *= 10;
currentValue += c - '0';
} // end of digit
// The end of the number signals a state change
handlePreviousState ();
// set the new state, if we recognize it
switch (c)
case 'R':
state = GOT_R;
case 'S':
state = GOT_S;
case 'G':
state = GOT_G;
default:
state = NONE;
} // end of switch on incoming byte
} // end of not digit
} // end of processIncomingByte
void loop ()
while (Serial.available ())
processIncomingByte (Serial.read ());
// do other stuff in loop as required
} // end of loop
This is where it evaluates numbers:
if (isdigit (c))
currentValue *= 10;
} // end of digit
You can use it, just figure out the else part that fits your need.
Do you ignore letters or count them as errors?
How do you handle errors? How well do you treat the user?
Input routines that catch errors and let the user take up from just before the bad key was hit save time re-typing what was good. I got appreciation for doing that back when the software was as primitive as the 8-bit bus hardware. It beat the make em type the whole thing then beep+error message and prompt for that whole entry again over 1 mistype default method.
