ok, I am trying to make a simple menu system and it isn't cooperating. It should go check the button status on four buttons pulled high. With nothing down, it'll return 1111. With the 3rd button pressed it returns 1101. This works. If I comment the code to run the DEBUG section, it shows my presses correctly. But I cannot get the ifthens to react to it. I think its a variable type issue, but I'm really not sure since I have tried every combination I can think of.
And yes, it's poorly structured, and uses gotos... At this point though, I haven't really even decided how I want it to work in the end. Since I plan to have this 16x2 or 16x4 lcd, or maybe a better display with touch, as well as output the menu system via video signal to my 7in rearview mirror display, plus buttons and bluetooth and maybe even GSM controls, I imagine I'll be rebuilding it several times before I like it anyway.
Thanks in advance for any input!
//LCD D7 pin to digital pin 2
//LCD D6 pin to digital pin 3
//LCD D5 pin to digital pin 4
//LCD D4 pin to digital pin 5
//LCD Enable pin to digital pin 11
//LCD RS pin to digital pin 12
//LCD R/W pin to ground
//LCD VSS pin to ground
//LCD VCC pin to 5V
//10K resistor:
//ends to +5V and ground
//wiper to LCD VO pin (pin 3)
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
lcd.begin(16, 2);
lcd.setCursor(0, 0);
lcd.print("Avalanche Master");
lcd.setCursor(0, 1);
lcd.print(" Control System ");
delay(5000); // Holds LCD splash, but mainly halts code for 5 seconds b4 serial start to avoid programming issues.
Serial.println("Avalanche Master Control System");
lcd.clear();
pinMode(A1, INPUT);
pinMode(A2, INPUT);
pinMode(A3, INPUT);
pinMode(A4, INPUT);
pinMode(11, OUTPUT);
pinMode(12, OUTPUT);
pinMode(13, OUTPUT);
pinMode(A0, OUTPUT);
pinMode(A5, OUTPUT);
digitalWrite(A0, HIGH);
digitalWrite(A1, HIGH);
digitalWrite(A2, HIGH);
digitalWrite(A3, HIGH);
digitalWrite(A4, HIGH);
digitalWrite(A5, HIGH);
int mmitemnum = 1;
int avitemnum = 1;
int LTitemnum = 1;
String CurMenuItem = " ";
int cargolts = 0;
int interiorlts = 0;
String btread = "";
String button1 = "1";
String button2 = "1";
String button3 = "1";
String button4 = "1";
String buttonstate = "1111";
//goto MainMenu;
goto DEBUG;
CheckButtons:
button1 = digitalRead(A1);
button2 = digitalRead(A2);
button3 = digitalRead(A3);
button4 = digitalRead(A4);
buttonstate = button1 + button2 + button3 + button4;
return;
DEBUG:
lcd.print("ButtonState is:");
lcd.print(" " + buttonstate + " ");
delay(100);
goto CheckButtons;
goto DEBUG;
MainMenu:
if (mmitemnum == 1) {CurMenuItem = " A/V Options ";}
if (mmitemnum == 2) {CurMenuItem = " Accessories ";}
if (mmitemnum == 3) {CurMenuItem = " Lighting ";}
lcd.print(" MAIN MENU: ");
lcd.println(CurMenuItem);
goto CheckButtons;
Serial.println(buttonstate);
if (buttonstate = "1101"){
if (mmitemnum < 3) {
mmitemnum = mmitemnum + 1;
delay(100);
if (buttonstate = "1011"){
if (mmitemnum > 1) {
mmitemnum = mmitemnum - 1;
delay(100);
if (buttonstate = "1110"){
delay(100);
if (mmitemnum == 1) {goto AVMENU;}
if (mmitemnum == 3) {goto LIGHTMENU;}
goto Check4BT;
AVMENU:
if (avitemnum == 1) {CurMenuItem = " 1. ";}
if (avitemnum == 2) {CurMenuItem = " 2. ";}
if (avitemnum == 3) {CurMenuItem = " 3. Radio Reset ";}
lcd.print(" AUDIO/VIDEO ");
lcd.print(CurMenuItem);
goto CheckButtons;
if (buttonstate == "0111"){
delay(100);
goto MainMenu;
if (buttonstate == "1101"){
if (avitemnum < 3) {
avitemnum++;
delay(100);
if (buttonstate == "1011"){
if (avitemnum > 1) {
avitemnum--;
delay(100);
if (buttonstate == "1110"){
delay(100);
if (avitemnum == 3) {goto RadioReset;}
goto AVMENU;
ACCMENU:
goto MainMenu;
LIGHTMENU:
if (LTitemnum == 1) {
if (interiorlts == 0) {
CurMenuItem = " INT Lights OFF ";
if (interiorlts == 1) {
CurMenuItem = " INT Lights ON ";
if (LTitemnum == 2) {
if (cargolts == 0) {
CurMenuItem = "Cargo Lights OFF";
if (cargolts == 1) {
CurMenuItem = "Cargo Lights ON ";
if (LTitemnum == 3) {CurMenuItem = " 3. ";}
lcd.print(" LIGHTING ");
delay(100);
goto MainMenu;
if (LTitemnum < 3) {
LTitemnum++;
delay(100);
if (LTitemnum > 1) {
LTitemnum--;
delay(100);
delay(100);
interiorlts = 1;
digitalWrite(12, HIGH);
goto LIGHTMENU;
interiorlts = 0;
digitalWrite(12, LOW);
goto LIGHTMENU;
cargolts = 1;
digitalWrite(13, HIGH);
goto LIGHTMENU;
cargolts = 0;
digitalWrite(13, LOW);
goto LIGHTMENU;
goto LIGHTMENU;
RadioReset:
digitalWrite(11, HIGH);
delay(3000);
digitalWrite(11, LOW);
lcd.print(" COMPLETE! ");
delay(5000);
return;
Check4BT:
if (Serial.available() > 0)
{char btread = Serial.read();
if (btread == "L")
digitalWrite(A0, LOW);
lcd.print(" DOORS ARE ");
lcd.print(" LOCKED! ");
delay(4000);
if (btread == "U")
digitalWrite(A5, LOW);
lcd.print(" UNLOCKED! ");
delay(4000);
btread = "";
return;
