Simple Microphone amplifier/filter
Hi all,
I'm pretty sure this is a very posted question, but I could not find the answer using the search box.
I need a very simple mic amplifier, which could have a non flat response.
I just need it sensible enough (but also noise proof enough) to detect drops splashing or some other noises, to trigger a camera.
I found on the web several examples, but I think many of them over perform for my purposes.
It would be nice if the sensitivity could be electronically controllable by the arduino (but if the output is logarithmic, well, I don't need it).
Any hints?
try this
http://www.analog.com/static/imported-files/data_sheets/SSM2166.pdf
connect the output of the circuit to an analog input of the arduino.
You can do the sound recognition depending from the level in software.
Mike
tnx, I'll have a look to the datasheet.
Maybe I'll build a "preampli" module which I'll re-use for several projects.
