Simple Mood light code
Hi guys, I came across an instructables page for making a mood light with LEDs and a light diffuser. Ive implemented the provided code and it actually works a treat!
However, the code being does not fully make sense to me
// Smooth RGB mood lamp
// Changes an RGB LED's color smoothly
// The brightness of the leds follows these equations:
// Red = sin(x)
// Green = sin(x + PI/3)
// Blue = sin(x + 2PI/3)
// for x from 0 to PI
float RGB[3];
int redLed   = 11;  // red LED in Digital Pin 11 (PWM)
int greenLed = 5;  // green LED in Digital Pin 5 (PWM)
int yellowLed  = 3 ;   // yellow LED in Digital Pin 3 (PWM)
void setup(){
  pinMode(redLed,OUTPUT);  // tell arduino it's an output
  pinMode(greenLed,OUTPUT);// tell arduino it's an output
  pinMode(yellowLed,OUTPUT); // tell arduino it's an output
  // set all the outputs to low
  digitalWrite(redLed,LOW);
  digitalWrite(greenLed,LOW);
  digitalWrite(yellowLed,LOW);
void loop(){
  for (float x=0;x<PI;x=x+0.00001){
    RGB[0]=255*abs(sin(x*(180/PI)));           // calculate the brightness for the red led
    RGB[1]=255*abs(sin((x+PI/3)*(180/PI)));    // calculate the brightness for the green led
    RGB[2]=255*abs(sin((x+(2*PI)/3)*(180/PI)));// calculate the brightness for the blue led
    analogWrite(redLed, RGB[0]);
    analogWrite(greenLed, RGB[1]);
    analogWrite(yellowLed, RGB[2]);
    for(int i=0;i<3;i++){
      if(RGB[i]<1){
        delay(100);
      if(RGB[i]<5){
        delay(50);
      if(RGB[i]<10){
        delay(10);
      if(RGB[i]<100){
        delay(5);
    delay(1);
I dont understand the point of using the sin PI business…i mean…is that really necessary ?
Could someone please enlighten me?
Thanks in advance
The sin() function takes care that the values increase/decrease gradually like a wave. You could use any waveform linear triangle etc but sin() is build in ....
Oh i see, so thats actually like an arduino pre-written functions or something?
Cool :) I never realised I could use that.
it is a standard math function - http://en.wikipedia.org/wiki/Sine -
Yes I'm aware of that, just didn't know it worked with Arduino.
