hi can someone please help. I need to hand in my homework in less than a week, please someone give me the code and how to place the wire in the Arduino board.
I need to make a system whenever the infrared IR sensor detects an object, inactivates the motor and the temperature and humidity sensor. And the temperature and humidity sensor controls the speed of the motor. I only have a Arduino board, bread board, battery box, some wires and the two sensors. I don't have any resistors and transistors.
Post your sketch, well formated, with comments and in so called code tags "</>" and schematic to see how we can help.
You seem to have been lazy about starting this project.
I'm pretty sure that you didn't received this task on 22. December 2022 and have to do it over chrismas and be finished on 2nd January 2023.
I hope you have learned this lesson now:
If you get a task / project to do that is very new to you
hurry up to ask experts "how long does it usually take to finish such a project?"
If you can contact your teacher you should contact your teacher as soon as possible
Saying that you are sorry for beeing so lazy - if you can have 14 days to finish this project.
If you get this permission you have 13 days with each day 8 to 10 hours work to learn about electronics and learn about how to write code.
If you don't get this permission in my opinion you are worth receiving a bad grade for the failed project
depends very much on the sensors if it will work or not.
How should anybody even write code if it is totally unclear what kind of sensors you have??
The microcontroller-world is not superstandardised like USB-devices.
You have to take care of more than just "does the plug fit into the socket?"
Hurry up
writing the exact type of sensors that you have
-writing the exact type of Arduino that you have (Arduino-Uno, Arduino-Mega, Arduino-Nano, Arduino-micro etc.)
Post pictures of the sensors
To become able to post pictures proceed to trust-level one
Get to trust level 1 by…
