Simple PID controller using Pt100 , Max31865 lcd display and relay
I’m trying to find an example of this to help me learn and add to.
I have no experience in writing code. But have been using tinkercad and Fritzing to play around with different arduino setups.
I like tinkercad because you can simulate it without hooking anything up.
I have general knowledge of electronics. It’s the coding that is giving me the problems.
I find I can modify code no problem and read it and somewhat understand it and how it applies to the arduino. But starting a code from scratch has me just staring at a blank screen.
Basically what I’m trying to do is build a simple PID temp controller that when the liquid reaches a certain temperature that is adjustable by user it activates a relay that controls a motorized ball valve. When the temperature cools down the relay powers down and ball valve closes.
I’d like to use a PT100 RTd sensor. For accuracy.
Max31865 amplifier
16x2 lcd
Maybe a push button to increase set temp and a push button to decrease set temp.
I would suggest you to try Proteus software for simulating Arduino Projects. You can easily add Arduino Library for Proteus and then can test your code on it.
First of all simulate Arduino with LCD, that will give you some understanding of how Arduino code works. After that use DS18B20 temperature sensor and use 12V DC Motor as fan and then design a simple PID controller which will control the speed of motor as the temperature changes.
If you got into trouble then can ask here and will get help.
Thanks.
