Simple Pointers
Hi!
Got a small error when trying to compile the following:
/***** LIBRARIES AND HEADERS *****/
#include <string.h>
  char buffer[50];
  char *prt;
  int i;
  int length;
  strcpy(buffer, "When in the course of human events");
  char ptr = buffer;
  length = strlen(buffer);
  Serial.print("The lvalue forptr is: ");
  Serial.print((unsigned int)&ptr);
  Serial.print(" and the rvalue is ");
  Serial.println((unsigned int)ptr);
  while (*ptr)
      Serial.print(*ptr++);
  Serial.flush();  // Make sure all the data is sent...
  exit(0);
I’m getting this error: ‘ptr’ was not declared in this scope
So if I humored the compiler, and I modified the line where the error occurred:
prt = buffer;
to
char ptr = buffer;
I get the following error:
pointer_math_1:32:11: error: invalid type argument of unary '*' (have 'char')
   while (*ptr)
pointer_math_1:34:24: error: invalid type argument of unary '*' (have 'char')
exit status 1
Any idea why I’m getting these errors?
prt is not the same as ptr char* ptr = buffer;
You also define prt as a pointer in one place and then define non-pointer one with a similar name at a different place
  char buffer[50];
  char *prt;                                                       // definition of prt
  int i;
  int length;
  char ptr = buffer;                                               // definition of ptr
Which to you really want to use? If this is a typo, that's one issue. If it's not, then why select two variables with such similar names??
