Simple Problem, Confusing Error... HELP!
So, the purpose of this code is to display a number by flashing a light… ie, the number 213 would be displayed as: flash-falsh… flash… flash-flash-flash.
This is designed to run as a loop, 20 cycles a second, turning the light on and off as needed. This sketch will be integrated into a much larger project (a rocket flight computer, the light flashing tells you the highest altitude).
So, for what ever reason, the sketch is stuck on the first digit. I ran diagnostics and found that while the “digit++” command at the bottom is occurring and increasing the value of “digit” by 1, “digit” goes back to a value of 1 when the loop restarts… help?
FYI: Instead of an LED flashing (I dont have one at the moment), it is transmitting something via Serial so the Serial light flashes…
//Example sketch for taking a 5 digit integer split it into digits and flash an LED to display them.
int integer = 32345;
int digit1;
int digit2;
int digit3;
int digit4;
int digit5;
int digit6;
int dig;
int digit;
int flashnum;
int fcount;
int count;
int dcount;
 //find digits
digit1 = integer/10000;
digit2 = (integer-10000*digit1)/1000;
digit3 = (integer-10000*digit1-1000*digit2)/100;
digit4 = (integer-10000*digit1-1000*digit2-100*digit3)/10;
digit5 = integer-10000*digit1-1000*digit2-100*digit3-10*digit4;
Serial.println(digit1);
Serial.println(digit2);
Serial.println(digit3);
Serial.println(digit4);
Serial.println(digit5);
  delay(50);
  if (digit=1)
      dig = digit1;
  else if (digit=2)
      dig = digit2;
  else if (digit=3)
      dig = digit3;
  else if (digit=4)
      dig = digit5;
  else if (digit=5)
      if (count<60)
          count++;
          Serial.print("^^");
  if (flashnum < dig)
      if (fcount < 5)
          Serial.print(flashnum);
          fcount++;
      else if (fcount < 10)
          fcount++;
      else if (fcount = 10)
          fcount=0;
          flashnum++;
       if (dcount < 30)
          dcount++;
          flashnum=0;
          if (digit=1)
            digit=2;
          else if (digit=2)
            digit=3;
          else if (digit=3)
            digit=4;
          else if (digit=4)
            digit=5;
          else if (digit=5)
            digit=6;
          else if (digit=6)
            digit=7;
          dcount=0;
}//end of loop
if (digit=1)
Look here
Thanks, I have done that before!
rpmaurer:
You'll probably do it again, too. 8) So will I......
