I have a simple code for testing the Serial port usage. I swear I tried the exact code earlier and it functioned properly. So either I'm going blind or there is some other Issue I can't put my finger on.
Any suggestions?
Thanks
John
//Print/Write test to CC2530 as UART (38400)
// Pin Assignments:
const int ledPin = LED_BUILTIN;
// Globals:
byte ETX=0x03; // end of text
byte array[]={0x74,0x67,ETX};
// Setup:
void setup(){
Serial.begin(38400);
pinMode(ledPin, OUTPUT);
} // ...setup
unsigned long currentMillis;
unsigned long previousMillis;
uint16_t interval = 10000;
// === MAIN LOOP ==================================================================
currentMillis = millis();
if (currentMillis - previousMillis >= interval) {
Serial.write(array);
asm ("sbi %0, %1 \n": : "I" (_SFR_IO_ADDR(PINB)), "I" (PINB5)); // toggle LED
} // .... main loop
// === end MAIN LOOP ==============================================================
// .... eof
I get the following errors:
C:\Users\John\Documents\Arduino\UART-cc2530\CC_UART_02\CC_UART_02.ino: In function 'void loop()':
C:\Users\John\Documents\Arduino\UART-cc2530\CC_UART_02\CC_UART_02.ino:38:27: error: no matching function for call to 'write(byte [3])'
In file included from C:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino/Arduino.h:233:0,
from C:\Users\John\AppData\Local\Temp\arduino-sketch-06CB6ED0543AF21AB9F890A5349A424D\sketch\CC_UART_02.ino.cpp:1:
C:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino/HardwareSerial.h:129:20: note: candidate: virtual size_t HardwareSerial::write(uint8_t) <near match>
virtual size_t write(uint8_t);
C:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino/HardwareSerial.h:129:20: note: conversion of argument 1 would be ill-formed:
C:\Users\John\Documents\Arduino\UART-cc2530\CC_UART_02\CC_UART_02.ino:38:27: warning: invalid conversion from 'byte* {aka unsigned char*}' to 'uint8_t {aka unsigned char}' [-fpermissive]
C:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino/HardwareSerial.h:130:19: note: candidate: size_t HardwareSerial::write(long unsigned int) <near match>
inline size_t write(unsigned long n) { return write((uint8_t)n); }
C:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino/HardwareSerial.h:130:19: note: conversion of argument 1 would be ill-formed:
C:\Users\John\Documents\Arduino\UART-cc2530\CC_UART_02\CC_UART_02.ino:38:27: warning: invalid conversion from 'byte* {aka unsigned char*}' to 'long unsigned int' [-fpermissive]
C:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino/HardwareSerial.h:131:19: note: candidate: size_t HardwareSerial::write(long int) <near match>
inline size_t write(long n) { return write((uint8_t)n); }
C:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino/HardwareSerial.h:131:19: note: conversion of argument 1 would be ill-formed:
C:\Users\John\Documents\Arduino\UART-cc2530\CC_UART_02\CC_UART_02.ino:38:27: warning: invalid conversion from 'byte* {aka unsigned char*}' to 'long int' [-fpermissive]
C:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino/HardwareSerial.h:132:19: note: candidate: size_t HardwareSerial::write(unsigned int) <near match>
inline size_t write(unsigned int n) { return write((uint8_t)n); }
C:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino/HardwareSerial.h:132:19: note: conversion of argument 1 would be ill-formed:
C:\Users\John\Documents\Arduino\UART-cc2530\CC_UART_02\CC_UART_02.ino:38:27: warning: invalid conversion from 'byte* {aka unsigned char*}' to 'unsigned int' [-fpermissive]
C:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino/HardwareSerial.h:133:19: note: candidate: size_t HardwareSerial::write(int) <near match>
inline size_t write(int n) { return write((uint8_t)n); }
C:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino/HardwareSerial.h:133:19: note: conversion of argument 1 would be ill-formed:
C:\Users\John\Documents\Arduino\UART-cc2530\CC_UART_02\CC_UART_02.ino:38:27: warning: invalid conversion from 'byte* {aka unsigned char*}' to 'int' [-fpermissive]
In file included from C:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino/Stream.h:26:0,
from C:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino/HardwareSerial.h:29,
from C:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino/Arduino.h:233,
C:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino/Print.h:52:12: note: candidate: size_t Print::write(const char*) <near match>
size_t write(const char *str) {
C:\Users\John\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.8.5\cores\arduino/Print.h:52:12: note: conversion of argument 1 would be ill-formed:
C:\Users\John\Documents\Arduino\UART-cc2530\CC_UART_02\CC_UART_02.ino:38:27: warning: invalid conversion from 'byte* {aka unsigned char*}' to 'const char*' [-fpermissive]
Compilation error: exit status 1
