simple programming but im new
So im very very new to programming im trying to build an automatic watering system for my plants, so the moisture sensor works but i dont really know how to trigger with relay to fire the pump when the moisture sensor detects no water.
int msensor = A1;
int msvalue = 0;
int Relay = 8;
int val;
boolean flag = false;
pinMode(msensor, INPUT);
pinMode(Relay, OUTPUT);
msvalue = analogRead(msensor);
Serial.println(msvalue);
if ( (msvalue >= 500 ) && ( flag == false ) )
digitalWrite(Relay, HIGH);
flag = true;
if ( ( msvalue <= 300 ) && ( flag == true ) )
digitalWrite(Relay, LOW);
flag = false;
val = analogRead(A1);{
if ( (msvalue <= 300 == LOW) ;
digitalWrite(13,LOW);
digitalWrite(13,HIGH);
delay(800);
delay(1000){;
WOW, that program layout is a mess
Here it is Auto formatted in the IDE and posted here in code tags
int msensor = A1;
int msvalue = 0;
int Relay = 8;
int val;
    flag = true;
    flag = false;
digitalWrite(13, LOW);
    digitalWrite(13, HIGH);
  delay(800);
  delay(1000)
You seem to have sprayed { and } around liberally without knowing what they are used for and invented your own syntax such as
    if ( (msvalue <= 300 == LOW) ; I have no idea what that is supposed to do. Needless to say the code does not compile
Start small. Read the sensor and print what it returns
ok thank you :frowning: just got a bit too excited :confused:
the code looks like it should work. Not sure it compiles with
delay(1000){;
suggest you replace everything from
thru the end of the file with a closing brace, "}" and set the LED to the same value the you set the Relay whenever you set the Relay.
assume your prints show that msvalue goes above 500 and below 300?
a relay may require more current than an Arduino output can supply. may need a transistor
