Hello guys, here´s the case... I have a simple project. A cc motor must rotate clockwise, anti-clockwise or stop based on the reads I get from 2 LDR´s.
I made the following part of the code:
valor1 = analogRead(analogin1);
valor2 = analogRead(analogin2);
dif = valor1 - valor2;
Serial.print(valor1);
Serial.print(" ; ");
Serial.print(valor2);
Serial.println(dif);
if(dif > 40){
// put motor in forward motion
digitalWrite(motor1APin, LOW); // set leg 1 of the H-bridge low
digitalWrite(motor2APin, HIGH); // set leg 2 of the H-bridge high
// control the speed 0- 255
speed_value_motor1 = 160;
analogWrite(speedPin, speed_value_motor1); // output speed as
// PWM value
else if(dif < 40){
// put motor in backward motion
digitalWrite(motor1APin, HIGH); // set leg 1 of the H-bridge low
digitalWrite(motor2APin, LOW); // set leg 2 of the H-bridge high
// PWM value
else{
// stop the motor
speed_value_motor1 = 0;
// PWM value
It works partially! The motor changes the direction if a LDR receives more light or the other. But when the difference between the reads of the LDR´s is less than 40, the motor just don´t stop! What am I doing wrong?
Hope you understood everything I said here =P
Thanks all!
