Simple Programming Question on a exponent function
In a tutorial for functions the following code was given:
// Use this in your power() function
int my_power;
// Needed by the test
int answer;
  // Should be 9
  answer = power(3, 2);
  Serial.println(answer);
  // Should be 5
  answer = power(5, 1);
  // Should be 1
  answer = power(9, 0);
  // Should be 16384
  answer = power(2, 14);
  // Should be 0
  answer = power(0, 4);
  // Do nothing
int power(int x, int y) {
  // Special case: if y is 0, return 1
  if ( y == 0 ) {
    return 1;
  // Store x argument in the my_power variable
  my_power = x;
  // Count down using y. Multiply my_power by x for each iteration
  while ( y > 1 ) {
    my_power *= x;
    y--;
  // Return the accumulated value in my_power
  return my_power;
There is a lot of stuff I undersand. Im going to list them for the sake of being organized.
  1. Isn't the x variable the base? Why was it assigned to my power varibable?
  2. I tried the test cases and plugged them in but I couldn't get them to work? Can you help me please?
  3. What does the *= mean?
Thanks!
Have you tried entering the words "c++ *=" into your internet search engine and view the results?
  1. Why are "my_power" and "variable" both globals?
  1. my_power is just a name... I don't think it needs to be static and the name doesn't fit the use, but it's just a name.
  2. sure, see updated code below
  3. it's a compound operator, x *= y is the same as x = x * y
  int answer = power(3, 2);
  // Do nothing
int power(int base, int power) {
  int response = base;
  if ( power == 0 ) return 1;
  for (int i = 1; i < power; i++) response *= base;
  return response;
Perehama:
It isn't.
engineer123498:
Because x^2 is xx and x^3 is xxx. If 'my_power' was left as 0 you would always get 0: 0x, 0xx, ...
engineer123498:
What answers did you get?
engineer123498:
3. What does the
mean?
The expression "x *= y" is a shortcut for the expression "x = x * y". Also works with "+=", "-=", "/="... Pretty much any operator you can put between two numbers. (Not '=='. You can't use "x === y;'.)
Your sketch works fine for me. I ran it on an Arduino UNO and got these results on Serial Monitor:
9
5
1
16384
0
johnwasser:
Because x^2 is xx and x^3 is xx*x.
sp. "x2 is xx and x3 is xx*x"
same function a third way...
  int response = 1;
  for (; power !=0; --power) response *= base;
  return response;
all of these only work if y is 0 or a positive integer.
Its not that the code doesn't work..its I just have no idea how it works.
As I said, the x variable which is the base, is assigned to my power, which confused me Could somone please walk me trough how it works? Im new to functions and this was really confusing. Thanks!
a 4th way...
  double answer = pow(3, 2);
  answer = pow(5, 1);
  answer = pow(9, 0);
  answer = pow(2, 14);
  answer = pow(0, 4);
  // Do nothing
engineer123498:
Your version had comments next to each line in the code. Did you put those there or do you have trouble understanding those comments?
a 5th way...
int power(int base, int exponent) {
    if (exponent != 0)
        return (base * power(base, exponent - 1));
        return 1;
Perehama:
a 5th way...
if (exponent != 0)
    return 1;
. power (3, -1);
Oops.
TheMemberFormerlyKnownAsAWOL:
. power (3, -1);
Oops.
as stated, these the OP code, 1, 2, 3 and 5 only work if y is 0 or a positive int. for negative exponents, use the avr-libc function pow() as in #4...
  answer = pow(5, 1);
  answer = pow(9, 0);
  answer = pow(0, 4);
  answer = pow(3, -1);
  // Do nothing
engineer123498:
To raise x to the power of y it multiplies x by itself 'y' times. It starts by saving 'x' in a variable (named 'my_power' but the name is not important). That variable is then multiplied by 'x' and stored back in the variable 'y-1' times. The repeat is done with "while (y > 1)" which repeats until 'y' is 1 or less. After the multiply, 'y' is decremented by 1: "y--;" which is a shortcut for "y -= 1;" which is a shortcut for "y = y - 1;".
Some simple examples:
If y starts as 2:
x gets saved in my_power
the while() loop runs because y (2) is greater than 1
my_power gets multiplied by x so it now contains xx
y gets decremented to 1
the while() loop ends because y (1) is not greater than 1.
my_power still contains x
x
If y starts as 3:
the while() loop runs because y (3) is greater than 1
y gets decremented to 2
the while() loop runs because y (2) is still greater than 1
xx
x*x
