When you subtract a quantity from an unsigned integer such that it would become negative, am I correct in thinking it "loops around"?
So, subtracting 1 from zero=255?
Sorry for the noob quotient inherent in this question.
(deleted)
Try it with a byte, which is, of course an unsigned integer (but not an unsigned int)
Try this
byte byte1 = 0;
byte1--;
Serial.println(byte1);
byte byte2 = 0;
byte2 = byte2 - 1;
Serial.println(byte2);
byte byte3 = 0;
Serial.println(byte3 - 1);
Before running it predict the results
jeric_synergy:
That would be true if you are using a byte which is an unsigned 8 bit value
An unsigned int is a 16 bit value so 0 - 1 gives 65535
...R
