system
September 10, 2014, 10:44pm
1
I am learning on the Uno and have made a simple 7 segment display sketch and made a function for each "number" so the right segments light when that numbers function is called.
Can a function name have a variable in it? or an array?
right now I have;
void loop(){
numberOne();
numberClear();
numberTwo();
numberClear();
numberThree();
numberClear();
numberFour();
numberClear();
numberFive();
numberClear();
Rather than call each number individually, I would like to just use a for loop for example.
Thanks
Jeff
KC9QQM
system
September 10, 2014, 10:46pm
2
Please post your entire code (that includes declarations and definitions , setup etc ) when asking software questions .
you most certainly can do what you want with function pointers.
I did this example for someone here earlier....
note how you can use it in a for loop in this simple example, enter an 'X' into the serial display to see it function:
void (*myFunction[2])(void);
myFunction[0] = myFunction1;
myFunction[1] = myFunction2;
pinMode(13, OUTPUT);
void myFunction1(void)
Serial.println("Function ONE");
digitalWrite(13, !digitalRead(13));
void myFunction2(void)
Serial.println("Function TWO");
if (Serial.available() > 0)
char myChar = Serial.read();
if (myChar == 'X')
for (int i = 0; i < 2; i++)
myFunction[i]();//<<<<<<<<<<<<<<<<<<<<<<<<<< function call here<<<<<<<<<<<
another example using on-board LED and either a button press or entering a character into the serial monitor
#include <math.h>
#define NUMBER_OF_ROUTINES 10
#define DEBUG
#ifdef DEBUG
#define DEBUG_PRINTLN(x) Serial.println(x)
#define DEBUG_PRINT(x) Serial.print(x)
#else
#endif
void (*ledFunction[NUMBER_OF_ROUTINES])(void);
byte ledPin = 13;
byte buttonPin = 2;
byte lastPressed;
byte state = 0;
byte increment = 5;
byte briteness;
unsigned long startTime;
boolean printed = false;
ledFunction[0] = ledFunction0;
ledFunction[1] = ledFunction1;
ledFunction[2] = ledFunction2;
ledFunction[3] = ledFunction3;
ledFunction[4] = ledFunction4;
ledFunction[5] = ledFunction5;
ledFunction[6] = ledFunction6;
ledFunction[7] = ledFunction7;
ledFunction[8] = ledFunction8;
ledFunction[9] = ledFunction9;
pinMode(ledPin, OUTPUT);
pinMode(buttonPin, INPUT_PULLUP);
int pressed = digitalRead(buttonPin);
if (pressed == LOW)
if (pressed != lastPressed)
state++;
printed = false;
lastPressed = pressed;
if (Serial.available())
state++;
printed = false;
if (state >= NUMBER_OF_ROUTINES) state = 0;
ledFunction[state]();
void ledFunction0()
if (!printed)
DEBUG_PRINTLN(F("Math Fade"));
printed = true;
float val = (exp(sin(millis()/2000.0*PI)) - 0.36787944)*108.0;
analogWrite(ledPin, val);
void ledFunction1()
if (!printed)
DEBUG_PRINTLN(F("Fast Flash"));
printed = true;
if (millis() - startTime >= 100UL)
digitalWrite(ledPin, !digitalRead(ledPin));
startTime += 100UL;
void ledFunction2()
if (!printed)
DEBUG_PRINTLN(F("Slow Flash"));
printed = true;
if (millis() - startTime >= 500UL)
startTime += 500UL;
void ledFunction3()
if (!printed)
DEBUG_PRINTLN(F("2.5% Duty Cycle Flash"));
printed = true;
unsigned long nowMillis = millis();
if (nowMillis - startTime < 25UL)
digitalWrite(ledPin, HIGH);
if (nowMillis - startTime < 1000UL)
digitalWrite(ledPin, LOW);
startTime += 1000UL;
void ledFunction4()
if (!printed)
DEBUG_PRINTLN(F("Quick Fade"));
printed = true;
if (millis() - startTime >= 10UL)
briteness += increment;
if (briteness >= 255 || briteness <= 0) increment = - increment;
analogWrite(ledPin, briteness);
startTime += 10UL;
void ledFunction5()
if (!printed)
DEBUG_PRINTLN(F("Slow Fade"));
printed = true;
if (millis() - startTime >= 35UL)
startTime += 35UL;
void ledFunction6()
static boolean fadeNow;
if (!printed)
DEBUG_PRINTLN(F("Fade Down and Up with Pause"));
printed = true;
if (millis() - startTime > 1000UL)
fadeNow = true;
briteness = 255;
increment = -5;
if (fadeNow)
for (int j = 0; j <= 255; j += 5)
delay(25);
fadeNow = false;
void ledFunction7()
if (!printed)
DEBUG_PRINTLN(F("Fade Up then Down with Pause"));
printed = true;
fadeNow = true;
briteness = 0;
increment = 5;
if (fadeNow)
delay(25);
fadeNow = false;
void ledFunction8()
if (!printed)
DEBUG_PRINTLN(F("Led On"));
printed = true;
void ledFunction9()
if (!printed)
DEBUG_PRINTLN(F("Led Off"));
printed = true;
