Simple question of parameter
Hi arduino~
I have very simple question but nowhere to ask
If i make a function like
void hello()
   something is here
something like this!
main question is this
If I have parameter made in loop
that parameter must be local parameter and cannot be used at hello()
then! we have to declare parameter as global parameter
but this parameter should change consistently as sensor received
How can I use the value from loop at other function?
please help me
Hello,
Make 'value' a parameter of the function
http://www.cplusplus.com/doc/tutorial/functions/
It is perfectly practical to use a global variable - the fact that it changes regularly does not matter if it meets your need.
The alternative is to pass a parameter to your function - something like
void hello( int myValue) {
  // use myValue within the function
  int someValue = 23;
  hello(someValue);
but if you do it like that the actions taken within hello() won't be accessible in loop() unless you extend the function hello() so that it returns a result.
...R
Robin2:
  int someValue = 23;
  hello(someValue);
Or make the function take a pointer and pass the pointer to the variable :wink:
sterretje:
You need oxygen when you get that far up the learning curve :slight_smile:
...R
sterretje:
ah pointer! that could be helpful
I didn't even recognize that is in arduino lol thx for help
Robin2:
 int someValue = 23;
 hello(someValue);
...R
ah~use like that
thx for your advice!
