Simple question on if else statement
Hi all,
I am sorry for this simple question. I am still learning Arduino code.
Currently I am doing this following code; to read input from user for the char of m (which refer to minute) or s (second).
Serial.println("Is it in min or sec? (m/s)");
    while (Serial.available() == 0);
      char i = Serial.parseFloat();
      if (i = 'm')
        Serial.print("ts = ");
        Serial.print(h, DEC);  //h refers to the input int written by user previously
        Serial.println(" min");
      else if (i = 's')
         Serial.println(" sec");
        Serial.println("Error!!");
When I run the code, and click serial monitor, here is the result:
  • if user enters 'm', it will display min.
  • if user enters 's', it will still display min.
  • if user enters other than m/s, it still displaying min.
but what I want the code to do is
  • whenever user enters 'm' it will show min
  • whenever user enters 's' it will show sec
  • whenever user enters other characters beside 'm' or 's', the error warning will display and the code will ask again the user to input m/s.
Thank you in advance for your help and kindness.
Why the braces?
if (i = 's')
if (i = 'm') will give the value m to i, it will not compare i with m.
Comparison Operator
x == y (x is equal to y)
else if (i == 'm')
luxxtek:
Comparison Operator
else if (i == 'm')
I've done as you suggested, but the result displayed when I insert 'm', 's' or other characters than both alphabets mentioned is still 'Error!!'. Is that the correct way to write the if else statement?
pretty sure this is wrong;
you want a character, not a float
try Serial.read();
427v8:
try Serial.read();
Thank youuuuuu :slight_smile: you help me lot. May God bless you :slight_smile:
