Hi Guys,
So I'm making a little LED light strip. According to the ebay auction I got the LEDs from, each 5mm LED is rated at 3v.
First question is, which is the better way to wire a light strip like this - in parallel or in a series?
Second question, is since this requires 24v (8 leds x 3v/ea = 24v), and the arduino can only supply 5v, I need an outside power source, correct?
To make sure I understand how this works, I have an external power supply that can supply 12v of power at 1.5amps. Each LED only requires 20mA. Since the LED's require 20mA and 3v of power, that means I need a current of 160mA. So I bring in a resistor to drop the current to manageable levels. 1500 mA - 160 mA means I should have at least a 1340 Omh resistor, correct?
So the resistor restricts the current from the dc power supply to only the 160mA all 8 LEDs require. But it would still blow the LEDs since the voltage level is still at 12v, right? So would I use a transistor here so the LEDs get only the required voltage, or a potentiometer to limit the voltage if I wired the LEDs in parallel?
Thanks for any tips.
