Now I get this simple example. I was thinking loop2 would step right into the next if condition...
So if I modify loop1 as follows, I get the same result, only loop1 takes a hare over a millisecond where loop two takes a it over 2 milliseconds to complete...
void loop1() {
unsigned long timestamp = millis();
// Every 5 seconds write data
while (millis() - timestamp < 999) {
Serial.print("loop1 time = "); Serial.println(millis());
To print one character at 9600 bps takes just short of a millisecond - could that be your difference?
Without seeing the whole sketch, it is diifficult to judge, or see how you're timing this.
I was just reading millis() printed in the serial monitor.
The loops are basically the whole sketch, I just called them loop1, loop2 for discussion. Setup just sets the serial at full speed.
So the time printed in the first loop was:
loop1 time = 5001
loop1 time = 10002
loop1 time = 15003
loop1 time = 20004
and at some point it skipped a millisecond, indicated it was taking a bit longer.
The printed time for loop2 was:
-------------------loop2 time = 5003
-------------------loop2 time = 10005
-------------------loop2 time = 15007
-------------------loop2 time = 20010
Not exactly since I'm going from memory, but that was basically how I timed the loops. loop2 took longer, but I think you might be right, most of the time is printing the extra characters...
