simple question ?
Hi dear.
I need in this code
int pin = 7;
int duration[17];
byte sens[17];
byte cm[8];
  pinMode(pin, INPUT);
   Serial.println("  ");
  for (int i=0 ; i<17; i++){
  duration[i] = pulseIn(pin, HIGH);
  if(duration[i]<100 ) {sens[i]=0;}
  else if(duration[i]<250 & duration[i]> 200  ) {sens[i]=1;}
  else { sens[i]=1000; }
cm[0]=sens[9];
cm[1]=sens[10];
cm[2]=sens[11];
cm[3]=sens[12];
cm[4]=sens[13];
cm[5]=sens[14];
cm[6]=sens[15];
cm[7]=sens[16];
cm array is accouring 10101010010 so some binary. I need in cm’s all things put to sideby side in one variable not array.
For ex.
int cm[4]=(1,0,1,1)
how can I pull this things from cm array to a variable for ex
a=1011;
If I can do that I turn the a into Decimal.
Thank you
int cm[4] = { 1,0,1,1 };
int value = 0;
value += cm[3] * 1;
value += cm[2] * 2;
value += cm[1] * 4;
value += cm[0] * 8;
You can turn this into more efficient code by using a for() loop that keeps doubling the multiplication value.
const byte pin = 7;
  unsigned long a = 0;
  for (int i = 0 ; i < 17; i++)
    if (i >= 9 && i <= 16)
      a *= 10;  // For decimal.  (Use *= 2 for binary)
      if (pulseIn(pin, HIGH) > 200)
        a += 1;
  Serial.print("Value of 'a' is ");
  Serial.println(a);
