Simple RC Car Programming Issue
Hello Arduino world,
I am a newbie at working with the Arduino and I required some assistance with a projec that I am working on.
This is the code I am using:
int ir_pin = 2;				 //Sensor pin 1 wired through a 220 ohm resistor
int led_pin = 13;
int ledpin = 12;				   //"Ready to Receive" flag, not needed but nice
int debug = 1;				   //Serial connection must be started to debug
int start_bit = 2000;			 //Start bit threshold (Microseconds)
int bin_1 = 1000;				   //Binary 1 threshold (Microseconds)
int bin_0 = 400;				     //Binary 0 threshold (Microseconds)
 pinMode(led_pin, OUTPUT);		 //This shows when we're ready to receive
 pinMode(ir_pin, INPUT);
 pinMode(ledpin, OUTPUT);
 digitalWrite(led_pin, LOW);	 //not ready yet
 int key = getIRKey();	  //Fetch the key
 if (key != -1) {
   Serial.print("Key Recieved: ");
   Serial.println(key);
  if (key == 16) {
   digitalWrite(ledpin, HIGH);
   delay(10);
 else {
   digitalWrite (ledpin,LOW);
int getIRKey() {
 int data[12];
 digitalWrite(led_pin, HIGH);     //Ok, i'm ready to recieve
 while(pulseIn(ir_pin, LOW) < 2200) { //Wait for a start bit
 data[0] = pulseIn(ir_pin, LOW);	 //Start measuring bits, I only want low pulses
 data[1] = pulseIn(ir_pin, LOW);
 data[2] = pulseIn(ir_pin, LOW);
 data[3] = pulseIn(ir_pin, LOW);
 data[4] = pulseIn(ir_pin, LOW);
 data[5] = pulseIn(ir_pin, LOW);
 data[6] = pulseIn(ir_pin, LOW);
 data[7] = pulseIn(ir_pin, LOW);
 data[8] = pulseIn(ir_pin, LOW);
 data[9] = pulseIn(ir_pin, LOW);
 data[10] = pulseIn(ir_pin, LOW);
 data[11] = pulseIn(ir_pin, LOW);
 if(debug == 1) {
 for(int i=0;i<=11;i++) {		     //Parse them
   if (debug == 1) {
   if(data[i] > bin_1) {		     //is it a 1?
	 data[i] = 1;
   }  else {
	 if(data[i] > bin_0) {	     //is it a 0?
	   data[i] = 0;
	  data[i] = 2;			   //Flag the data as invalid; I don't know what it is!
 for(int i=0;i<=11;i++) {		     //Pre-check data for errors
   if(data[i] > 1) {
	 return -1;				   //Return -1 on invalid data
 int result = 0;
 int seed = 1;
 for(int i=11;i>=0;i--) {		    //Convert bits to integer
   if(data[i] == 1) {
	 result += seed;
   seed = seed * 2;
 return result;				     //Return key number
Basically, what I am attempting to do is to light up an LED every time I press a button on a remote with an IR sensor. The signal is received by the Arduino, however, I don't know // how to make it work the way I'd like to. When I press a button on the remote, the LED turns on but I want the LED to turn back off after I let go of the button; this code will later be assigned to a motor in which when I press the button, the RC car will go forward and when I let go of the button, the RC car will stop. As of now, I have to press a different button to turn off the LED. Please check the void loop code and see what's wrong.
That getIRKey routine blocks waiting for a key to be pressed. Thus the led stays on until you press another.
How would you make it that when you press the button (LED turns and stays on) and then when you let go of the button (LED goes off)?
UPDATED CODE:
int ir_pin = 2;
int led_pin = 13;
int ledLEFT = 12;
int ledFORWARD = 11;
int ledBACK = 10;
int ledRIGHT = 8;
int debug = 1;
int bin_1 = 1000;
int bin_0 = 400;
 pinMode(ledLEFT, OUTPUT);
 pinMode(ledFORWARD, OUTPUT);
 pinMode(ledBACK, OUTPUT);
 pinMode(ledRIGHT, OUTPUT);
 if (key != -1) {
   Serial.print("Key Received: ");
  if (key == 16) {                           //To go left + forward.
   digitalWrite(ledLEFT, HIGH);
   digitalWrite(ledFORWARD, HIGH);
   digitalWrite(ledBACK, LOW);
   digitalWrite(ledRIGHT, LOW);
   delay(100);
   digitalWrite(ledFORWARD, LOW);
  if (key == xxxx) {                         //To go forward.
   digitalWrite(ledLEFT, LOW);
   delay(100);
  if (key == 1040) {                         //To go right + forward.
   digitalWrite(ledRIGHT, HIGH);
   delay(100);
  if (key == 2064) {                         //To go left + back.
   digitalWrite(ledBACK, HIGH);
   delay(100);
  if (key == 528) {                          //To go back.
   delay(100);
  if (key == xxxx) {                         //To go right + back.
   delay(100);
  if (key == xxxx) {                         //To stop.
   delay(100);
int getIRKey() {
 int data[12];
 if(debug == 1) {
   if (debug == 1) {
	 data[i] = 1;
	   data[i] = 0;
	  data[i] = 2;
   if(data[i] > 1) {
	 return -1;
 int result = 0;
 int seed = 1;
   if(data[i] == 1) {
	 result += seed;
   seed = seed * 2;
 return result;
Jeremy Blum has an Arduino tutorial series, and episode 2 is mostly on the LEDs. @ the end of the video, he shows you how to toggle on/off.
I fixed up your code from any errors and made it simpler to understand:
int led_pin = 13;        // built in LED
int ledLEFT = 12;
int ledBACK = 10;
int ledRIGHT = 8;
int debug = 1;
int bin_1 = 1000;
int bin_0 = 400;
   if (key != -1)
   switch (key)
     case 16:                      // left + forward
       LF();
       break;
     //case xxxx:                    // forward
     //  f();
     //  break;
     case 1040:                    // right + forward
       RF();
       break;
     case 2064:                    // left + back
       LB();
       break;
     case 528:                     // back
       B();
       break;
     //case xxxx:                    // right + back
       RB();
       break;
     //case xxxx:                    // stop
     //  S();
     //  break;
     case -1:                      // no key received
       break;
  void LF()                          //To go left + forward.
    delay(100);
  void f()                     //To go forward.
     delay(100);
  void RF()                      //To go right + forward.
     delay(100);
  void LB() {                         //To go left + back.
    delay(100);
  void B() {                          //To go back.
    delay(100);
  void RB() {                         //To go right + back.
    delay(100);
  void S() {                         //To stop.
    delay(100);
int getIRKey() {
  int data[12];
 if (debug == 1) {
 for (int i=0; i<=11; i++) {
   if (debug == 1) {
	 data[i] = 1;
   else {
	   data[i] = 0; }
         else {
	   data[i] = 2;
 for (int i = 0; i <= 11; i++)
   if (data[i] > 1)
     return -1;
 int result = 0;
 int seed = 1;
 for(int i = 11; i >= 0; i--)
   if(data[i] == 1)
     result += seed;
   seed = seed * 2;
 return result;
