It's a really easy code but I struggled...
Comments welcomed... I'm new to coding.
Any shortcuts for what I've written or faults?
Thanks!
CONTROLLING A RELAY USING AN INPUT SIGNAL
WITH A 10 MINUTE TIMER (START, STOP/RESET)
Based on:
http://www.arduino.cc/en/Tutorial/BlinkWithoutDelay
// constants won't change. Used here to
// set pin numbers:
const int pumpPin = 13; // the number of the PUMP pin
const int pulseInput = 11; // the number of the PULSE pin
// Variables will change:
int pumpState = LOW; // pumpState used to set the PUMP
long startMillis = 0; // will store last time PUMP was updated
// the follow variables is a long because the time, measured in miliseconds,
// will quickly become a bigger number than can be stored in an int.
long timer = 1000*60*10; // timer of 10 minutes
// set the digital pin as output:
pinMode(pumpPin, OUTPUT);
digitalWrite(pumpPin, LOW);
pinMode(pulseInput, INPUT);
// Checking for the pulse
if (digitalRead(pulseInput) == HIGH){
if (pumpState == LOW)
pumpState = HIGH;
pumpState = LOW;
// Update, update, update...
// Load startMillis
if (pumpState == HIGH & startMillis == 0)
startMillis = currentMillis;
// If PumpState HIGH and Timer less than 10 minutes
if (pumpState == HIGH & currentMillis - startMillis < timer){
// Turn ON pump
digitalWrite(pumpPin, HIGH);
// Else turn OFF pump, reset startMillis and pumpState
else {
startMillis = 0;
pumpState = LOW;
} // End of Loop
All 3 literals are ints. The multiplication will be performed using int methods, regardless of the fact that you wish to store the result in a long and regardless of the fact that the multiplication will overflow. One or more of the literals needs UL tacked on the end.
Time is ALWAYS unsigned. Time does not flow backwards, except in Hollyweird.
The value being defined is an interval, not a timer. The name sucks.
Proper indenting might not matter to you or to the compiler. It does to me. Tools + Auto Format is you friend. Not using it will never make you mine.
Based on:
// set pin numbers:
unsigned long startMillis = 0; // will store last time PUMP was updated
unsigned long interval = 600000; // interval of 10 minutes
pumpState = HIGH;
pumpState = LOW;
// Load startMillis
if (pumpState == HIGH & currentMillis - startMillis < interval){
// Turn ON pump
else {
startMillis = 0;
pumpState = LOW;
Serial.println("END");
} // End of Loop
Next, you'll need to look at the state change detection example. You want to turn the pump on when the switch BECOMES pressed, not IS pressed, right? Then, separately, if the pump is on, and it has been on for the defined interval, you want to turn it off, right?
Something like this:
int currState;
int prevState = LOW;
unsigned long pumpOnTime;
currState = digitalRead(pulseInput);
if(currState != prevState)
// The switch became pressed or it became released
if(currState == HIGH)
// It became pressed...
// Turn the pump on and record the time
pumpOnTime = millis();
prevState = currState;
if(pumpOnTime > 0) // The pump is on
if(millis() - pumpOnTime > interval) // It's time to turn it off
// Turn the pump off and clear the on time
pumpOnTime = 0;
Thanks for the help. This is how it's looking so far.
It's all working.
Used an analog input for 3.3 signal and mapped it 0 and 1.
Also the pumps should be able to stop anytime.
int currState;
int pulseInput = 5;
int pumpPin = 12;
unsigned long interval;
interval = 1000UL*60*10;
currState = analogRead(pulseInput);
currState = map(currState, 0, 600, 0, 1);
// check if the pump is on to shut it off
if (pumpOnTime > 0) {
goto OFF; //Jump to OFF: tag.
if (pumpOnTime == 0) Serial.println ("IDLE");
Serial.println (millis() - pumpOnTime);
OFF:
pumpOnTime = 0;
