Hey friends,
I have very limited experience with arduino, so hopefully this makes sense.
This project will be a momentary switch that toggles between two 110v lamps. No timer, just latching on/on, the lamp stays on until the momentary switch is closed again and the 2nd lamp comes on.
Originally I was going to do this with a hand-wired flip-flip circuit and an SPDT relay. While that's pretty simple (for me), I had a couple of these arduino Duemilanoves around and figured it would be even easier and faster to use one instead.
I tried doing some searches, but couldn't find anything that would compile and run on the Duemilanove. Perhaps it is obsolete? I have everything I need to make it work, I just don't understand the script well enough.
Can anyone point me in the direction of a sketch that might work? Or a good place to start? The project is a film lightning prop, and I need to have it put together in 48hrs, so I don't have enough time to learn from scratch (but I will after this!)
If you can help me out I'm happy to send you whatever leftover parts I have (a couple arduinos and some fun FSRs and stuff). Or I can hook you up with something else, I know your time is valuable.
Thanks for all your help, in advance!
