Simple Relay. What am I doing wrong?
Hello!
I'm new to electronics. I'm building a project so a relay emulates a mouse click. I've soldered two wires off the left mouse button. I can touch the wires together and it works like a charm. The plan is to have an arduino-controlled relay complete the circuit. Almost all the relay-related posts deal with AC. I'm dealing with an USB mouse. The relay has NClosed and NOpen posts. Just to check, I hooked the mouse to NC and it clicked (and held) like I expected.
My parts list:
  • Radio Shack 5VDC Micromini Relay (12P08)
    IN4004 Rectifier Diode
    2N2222 Transistor
    1K Resistor
My code:
#include <Servo.h>
#include <Wire.h>
int mousePin = 7;
int baudRate = 9600;
void clickMouse()
  Serial.println ("Mouse Press");
  digitalWrite(mousePin, HIGH);
  delay (500);
  Serial.println ("Mouse Release");
  digitalWrite(mousePin, LOW);
  Serial.begin(baudRate);
  if (Serial.available() > 0) {
    int serialInput = Serial.read();
    switch (serialInput)
    case 'c':
        clickMouse();
Here is the project broken out on a breadboard:
Looking at the photo it seems like you have the right hand connection to the relay coil going to GND whereas it should be at +5v.
You forgot to set up the I/O pin as an output pin, all I/O pins default to be input pins when reset or powered on. Add the following line in your setup function:
pinMode(mousePin, OUTPUT); // sets the digital pin as output
Even on I/O pins that you might be going to use as input pins, it's a good idea to set them as input pins in your setup function for better understanding of the code for yourself and others in the future.
Read all about pinMode function:
Lefty
PS: Good form posting both your code and a picture of the wiring when asking for help or advice. Saves lots of time for all involved and a great example for other newcomers to emulate. :slight_smile:
Here here! :slight_smile:
To make it perfect you would only have had to select your code in the reply box and hit the # icon, the code would then appear in a scrolling box.
The Gods are pleased.
You are blessèd and righteous amongst Noobkind..
;D
Thank you all for your help!
...select your code in the reply box and hit the # icon
Done!
Re-routed per your post.
Ah, my mistake. Corrected.
I'm still not getting any response from the relay. I tested continuity on a multimeter and not a twitch.
The emitter of the transistor should be connected to GND, not +5v. (That is assuming it is an NPN transistor.)
IT WORKS! :smiley:
I'll post up final build code/photos. All of you make this fun and it's the supporting environment which will keep attracting more tinkerers.
-S
