I created the following program as a starting point for a project to turn and Arduino into a DMX controller.
I started by creating a simple program that when running will simply cycle my DMX lighting and an on-board RGB LED from one color to the next until it gets to the last color then repeat.
The problem is it always displays the last color of the sequence for twice as long as the rest. My programming skills are limited and I cannot figure out why. I am using millis() and not just delays as the next phase of the program will introduce an IR remote and a MIDI foot controller for additional inputs.
Please help if you can.
/* This program created by Ken Barrett on Mar 31, 2016
* It is design to use the Arduino Mega as a DMX controller
* It also uses a simple RGB LED as a debug light when no DMX device connected
* DMX channels controlled are as follows:
* 1. Red Par Can
* 2. Blue Par Can
* 3. Yellow Par Can
* 4. Green Par Can
* 5. Dimmer on Microh LEDP64KDII
* 0 - 189 Dimmer
* 190 - 250 Flash
* 251 - 255 No Function
* 6. Red channel of Microh LEDP64KDII
* 7. Green channel of Microh LEDP64KDII
* 8. Blue channel of Microh LEDP64KDII
* 9. Red channel of Ledge LED Strip Light
* 10. Green channel of Ledge LED Strip Light
* 11. Blue channel of Ledge LED Strip Light
* 12. Red channel of Left Box LED Strip Light
* 13. Green channel of Left Box LED Strip Light
* 14. Blue channel of Left Box LED Strip Light
* 15. Red channel of Right Box LED Strip Light
* 16. Green channel of Right Box LED Strip Light
* 17. Blue channel of Right Box LED Strip Light
#include <DmxSimple.h>
const int redPin = 11; // R petal on RGB LED module connected to digital pin 11
const int greenPin = 10; // G petal on RGB LED module connected to digital pin 10
const int bluePin = 9; // B petal on RGB LED module connected to digital pin 9
/* The most common pin for DMX output is pin 3, which DmxSimple
** uses by default. If you need to change that, do it here. */
const int dmxPin = 3; // DMX ouput pin selection
// constants used here to set max DMX channels:
const int maxChan = 17; // max DMX channels to be used
/* Use arrays to store the DMX channel intensities
* Each index of the array will correspond to a different channel
* Each scene will be a different array
* As DMX channels max out at 255 byte arrays will be used
* maxChan will be used to set the size of each array to easily
byte redScene[maxChan] = {255, 0, 0, 0, 189, 255, 0, 0, 255, 0, 0, 255, 0, 0, 255, 0, 0};
byte greenScene[maxChan] = {0, 0, 0, 255, 189, 0, 255, 0, 0, 255, 0, 0, 255, 0, 0, 255, 0};
byte blueScene[maxChan] = {0, 255, 0, 0, 189, 0, 0, 255, 0, 0, 255, 0, 0, 255, 0, 0, 255};
byte yellowScene[maxChan] = {0, 0, 255, 0, 189, 255, 255, 0, 255, 255, 0, 255, 255, 0, 255, 255, 0};
byte cyanScene[maxChan] = {0, 255, 0, 255, 189, 0, 255, 255, 0, 255, 255, 0, 255, 255, 0, 255, 255};
byte magentaScene[maxChan] = {255, 255, 0, 0, 189, 255, 0, 255, 255, 0, 255, 255, 0, 255, 255, 0, 255};
byte whiteScene[maxChan] = {255, 255, 255, 255, 189, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255, 255};
byte blackoutScene[maxChan] = {0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0};
// set variable for first scene array pointer
int currentScene = 0;
// Chases will use 2D arrays
// first create a variable for the max row pointer for each chase (one less than total rows)
int rgbChaseSize = 6;
// setup array for DMX chase scene values
byte rgbDmxchase [] [maxChan] = {
{255, 0, 0, 0, 189, 255, 0, 0, 255, 0, 0, 255, 0, 0, 255, 0, 0},
{0, 0, 0, 255, 189, 0, 255, 0, 0, 255, 0, 0, 255, 0, 0, 255, 0},
{0, 255, 0, 0, 189, 0, 0, 255, 0, 0, 255, 0, 0, 255, 0, 0, 255},
{255, 255, 0, 0, 189, 255, 0, 255, 255, 0, 255, 255, 0, 255, 255, 0, 255},
{0, 255, 0, 255, 189, 0, 255, 255, 0, 255, 255, 0, 255, 255, 0, 255, 255},
{0, 0, 255, 0, 189, 255, 255, 0, 255, 255, 0, 255, 255, 0, 255, 255, 0},
// setup array for RGB LED chase scene values
byte rgbLedchase [] [3] = {
{255, 0, 0},
{0, 255, 0},
{0, 0, 255},
{255, 0, 255},
{0, 255, 255},
{255, 255, 0},
{255, 255, 255}
// The value will quickly become too large for an int to store
unsigned long previousMillis = 0; // will store last time scene was changed
// setup constants for scene length and fade times :
const long sceneTime = 500; // interval for scene to stay on (milliseconds)
// const long fadeTime = 100; // interval to fade from scene to scene (milliseconds)
DmxSimple.usePin(dmxPin);
/* DMX devices typically need to receive a complete set of channels
** even if you only need to adjust the first channel. You can
** easily change the number of channels sent here. If you don't
** do this, DmxSimple will set the maximum channel number to the
** highest channel you DmxSimple.write() to. */
DmxSimple.maxChannel(maxChan);
// check to see if it's time to change the scene; that is, if the
// difference between the current time and last time you changed
// the scene is bigger than the interval (sceneTime) at which you want to
// hold the scene.
if (currentMillis - previousMillis >= sceneTime) {
// save the last time you changed the scene
// Scene has run long enough so it is time to change it
if (currentScene > rgbChaseSize) {
// once we have made it to the last row of array we need to reset to first
currentScene = 0;
for (int i=0; i < maxChan; i++){
// DMX channels start at 1 but arrays start at 0 so we need to create a channel variable
int chan = i + 1;
// set current channel to the value stored in the array
DmxSimple.write(chan, rgbDmxchase [currentScene] [i]);
// here we will output the RGB LED color for this scene in the chase
color(rgbLedchase [currentScene] [0], rgbLedchase [currentScene] [1], rgbLedchase [currentScene] [2]);
// all channels are now set so we can increment current scene
currentScene++;
void color (unsigned char red, unsigned char green, unsigned char blue) // the color generating function
analogWrite(redPin, red);
analogWrite(greenPin, green);
analogWrite(bluePin, blue);
Thanks Ken
