Simple robot
can some one point me in the right direction . I would like to use my ardunio (new) as a simple robot i have three servos (360deg) and a Sharp GP2d12 sensor I need to find some simple code to use it as obstical aviod using the sensor on a sweep servo I would expect to use 6 for sweep and 9-10 for servos wheels Digital PWM outputs and the sensor on analog in 0
Thank you for any assistance
Here's a start:
const int sensorPin = 0;
const int servo1Pin = 9;
const int servo2Pin = 10;
const int sweepPin = 6;
You'll make several copies of this, and add bits and pieces to loop(), to read data from the sensor, to sweep the servo, to spin the two other servos, etc.
When all those pieces work, you can begin combining them into a single sketch that makes the robot move while avoiding robots. As is, the robot will avoid any obstacle except stuff dropped on it.
Don't use PWM, use PPM from the Servo library.
Sharp GP2d12 sensor
Add the word Arduino to that and Google can be a big help.
Quote Sharp GP2d12 sensor
Quite so. http://arduino.cc/forum/index.php/topic,72188.msg540276.html#msg540276
Have a look for “makey” for hardware and software ideas
