I’m setting out my Yun to read several sensors in my house. When a sensor is triggered, I’d like to receive an email alerting me of the problem.
I set up a Temboo account and test it out successfully so my question is:
How do I set up a routine in Sketch so that when a sensor is triggered, I can receive an email?
String emailSubject("This is an automated email from your Arduino Yún. ");
String emailBody(“”);
if (moistureState == HIGH); { // if triggered send email
String emailBody(“”); // clear text
emailBody = "A water leak has been detected!!"
sendMail(emailSubject,emailBody);
if (tempState == HIGH); { // if triggered send email
emailBody = (“High temp has been detected”)
sendMail(emailSubject,emailBody) {
-- working Temboo code here--
Any help is appreciated.
TIA
This almost is always a mistake:
Note the semicolon between the closing parenthesis and the opening brace. Also, go to your source code window, put the cursor somewhere in the source code window and press Ctrl-T.
Thank you for pointing that out. It was a typo while typing the code (didn’t copy/paste it as the original code is in a different language).
My question is how do I write a routine so can just call it when needed.
Cheers.
If that was a typo, maybe these are too:
String emailBody("");
String emailBody(""); // clear text
emailBody = ("High temp has been detected")
When you call a function, you do not put the function type specifier in front of the call. Indeed, if these two functions return a String object type, you normally would be assigning the return value into something.
Thank you again.
I didn’t pay too much attention to my code as I was after the subroutine. Next time I’ll pass my code through Sketch.
Anyway, I found my answer here: http://forum.arduino.cc/index.php?topic=54578.0
No, we understand: Too much work for you to do before you post, so just let us do it rather than doing it yourself first.
ebolisa:
The code itself will still be readable. We tend to ignore comments anyway as they often don't really describe what is happening. Much better to copy and paste.
