simple scale to send sms when reach threshold
Hi guy so i have a project i am busy with and wanted to try arduino. i am totally new to the arduino world and i kinda have no idea what im doing. i want to build a simple scale that when it reached say 1kg it should send me a sms. i bought the arduino uno, a hx711, a dc to dc buck converter and a sim800l module. with that i took a bathroom scale apart and wired it up with the hx711 and downloaded the calibration code and it works perfect. but my problem lays when i use the full hx711 library and with to combine just a piece of the adafruit fona library it just throught all errors. now i have know idea how to code. is there anyone that has the complete code for me that i can cope and paste. or if someone can please help me with fixing my code.? i dont know what i am doing wrong or how to fix it. attached i have my code so far.
my code.txt (3.92 KB)
What errors do you get?
Would you please translate that into English, and give examples?
so i have been building another code. basically i just took the adafruit fona test library for the gsm and the hx711 library for the scale and used a part to send a sms and copied and paste it to the hx711 library but i keep on getting error codes. The error i am getting now is:
case label "s" not within a switch statement
when it complies the error is close to the bottom of the code so i assume everything on further up is ok but also dont know if i need to add something in futher up
#include <Adafruit_FONA.h>
#define FONA_RX 2
#define FONA_TX 3
#define FONA_RST 4
// this is a large buffer for replies
char replybuffer[255];
// We default to using software serial. If you want to use hardware serial
// (because softserial isnt supported) comment out the following three lines
// and uncomment the HardwareSerial line
#include <SoftwareSerial.h>
SoftwareSerial fonaSS = SoftwareSerial(FONA_TX, FONA_RX);
SoftwareSerial *fonaSerial = &fonaSS;
// Hardware serial is also possible!
//  HardwareSerial *fonaSerial = &Serial1;
// Use this for FONA 800 and 808s
Adafruit_FONA fona = Adafruit_FONA(FONA_RST);
// Use this one for FONA 3G
//Adafruit_FONA_3G fona = Adafruit_FONA_3G(FONA_RST);
uint8_t readline(char *buff, uint8_t maxbuff, uint16_t timeout = 0);
uint8_t type;
 * HX711 library for Arduino - example file
 * https://github.com/bogde/HX711
 * MIT License
 * (c) 2018 Bogdan Necula
#include "HX711.h"
// HX711 circuit wiring
const int LOADCELL_DOUT_PIN = 5;
const int LOADCELL_SCK_PIN = 6;
HX711 scale;
  Serial.begin(38400);
  Serial.println("HX711 Demo");
  Serial.println("Initializing the scale");
  // Initialize library with data output pin, clock input pin and gain factor.
  // Channel selection is made by passing the appropriate gain:
  // - With a gain factor of 64 or 128, channel A is selected
  // - With a gain factor of 32, channel B is selected
  // By omitting the gain factor parameter, the library
  // default "128" (Channel A) is used here.
  scale.begin(LOADCELL_DOUT_PIN, LOADCELL_SCK_PIN);
  Serial.println("Before setting up the scale:");
  Serial.print("read: \t\t");
  Serial.println(scale.read());      // print a raw reading from the ADC
  Serial.print("read average: \t\t");
  Serial.println(scale.read_average(20));   // print the average of 20 readings from the ADC
  Serial.print("get value: \t\t");
  Serial.println(scale.get_value(5));   // print the average of 5 readings from the ADC minus the tare weight (not set yet)
  Serial.print("get units: \t\t");
  Serial.println(scale.get_units(5), 1);  // print the average of 5 readings from the ADC minus tare weight (not set) divided
            // by the SCALE parameter (not set yet)
  scale.set_scale(2280.f);                      // this value is obtained by calibrating the scale with known weights; see the README for details
  scale.tare();               // reset the scale to 0
  Serial.println("After setting up the scale:");
  Serial.println(scale.get_value(5));   // print the average of 5 readings from the ADC minus the tare weight, set with tare()
  Serial.println(scale.get_units(5), 1);        // print the average of 5 readings from the ADC minus tare weight, divided
            // by the SCALE parameter set with set_scale
  Serial.println("Readings:");
  Serial.print("one reading:\t");
  Serial.print(scale.get_units(), 1);
  Serial.print("\t| average:\t");
  Serial.println(scale.get_units(10), 1);
   if ("scale.get_units()>30")
 case 's': {
        // send an SMS!
        char sendto[21], message[141];
        flushSerial();
        Serial.print(F("Send to #"));
        readline(sendto, 20);
        Serial.println(sendto);
        Serial.print(F("Type out one-line message (140 char): "));
        readline(message, 140);
        Serial.println(message);
        if (!fona.sendSMS(sendto, message)) {
          Serial.println(F("Failed"));
          Serial.println(F("Sent!"));
  scale.power_down();             // put the ADC in sleep mode
  delay(5000);
  scale.power_up();
