Simple Sensor-Data transmitter
Hi there,
I need to send data from an accelerometer (sparkfun triple axis accelerometer adxl362), to an arduino uno. The accelerometer has an SPI interface. So I need a very little and handy data-transmitter, which sends the data of the accelerometer to the arduino uno, coin cell battery powered.
I always thought at somethink like an XBee and XBee Explorer Regulated. Someone already did something like this and has a good advice or a tutorial for me?
thanks,
You mean TWO XBees and the board, right? You'll need some way to connect the 2nd XBee to the Uno. Powering the Uno from a coin cell battery is a non-starter, though. Unless you have one hell of a large coin.
PaulS:
No, I don't mean two XBees on one board.
Accelerometer - Tranmitter (Xbee?, the whole thing has to be very small) --------- 1 - 5m distance, wireless connection ->>>>>>>>>> Arduino Uno, Receiver.
Do I need an Arduino to use an Xbee as transmitter? Or is it possible to use an XBee "standalone"?
You plan to use one XBee as a receiver. What is it going to receive from?
The XBee can be used standalone, for some kinds of sensors. If the sensor requires a trigger from the thing it is connected to, before it returns data, then the trigger has to come from a programmable microcontroller.
PaulS:
thanks for your reply.
OK, so that means I would need a second arduino, to read the data from the accelerometer and "forward" it to an xbee. And as receiver I need another Xbee for my Arduino Uno.
So I need a very little arduino or another micro (which I don't know how to program yet...). How can I get that as small as possible? Because at the end, It should fit in wristband (I don't know if it is the exact word, you know, like a sweatband...)
So I found those LilyPads (found here)... And as I know, the accelerometer needs the digital pins 10 - 13, VCC and GND for the SPI protocol on the arduino uno (see here). With an ATmega328, It needs pins 17 - 19 (found here).
Is it possible to empower such a LilyPad Arduino Simple Board with only a coin-cell battery?
thanks,
