#define USART_RECEIVE_BUFFER_SIZE 80
unsigned char g_receiveBuffer [ USART_RECEIVE_BUFFER_SIZE ];
unsigned char g_receiveHead ;
unsigned char g_receiveTail ;
#define UCSR0A_ADDR (unsigned char *) 0xC0
#define UDR0_ADDR (unsigned char *) 0xC6
#define UCSR0A_RXC_MASK 0x80
#define UCSR0A_RXC_EMPTY 0x00
#define USART_TRANSMIT_BUFFER_SIZE 80
unsigned char g_transmitBuffer [ USART_TRANSMIT_BUFFER_SIZE ];
unsigned char g_transmitHead ;
unsigned char g_transmitTail ;
#define UCSR0B_ADDR (unsigned char *) 0xC1
#define UCSR0B_TXEN_MASK 0x08
#define UCSR0B_TXEN_ON 0x08
#define UCSR0B_TXEN_OFF 0x00
#define SREG_ADDR (unsigned char *) 0x5F
#define SREG_GLOBAL_INT_ENABLE 0x80
#define FORCE_0_MASK 0x7F;
unsigned char *portDDRD;
unsigned char *portD;
unsigned char *uControlandStatusRegisterA;
unsigned char *uControlandStatusRegisterB;
unsigned char *uControlandStatusRegisterC;
unsigned char *baudRateRegisterH;
unsigned char *baudRateRegisterL;
uControlandStatusRegisterA = (unsigned char *) 0xC0;
uControlandStatusRegisterB = (unsigned char *) 0xC1;
uControlandStatusRegisterC = (unsigned char *) 0xC2;
baudRateRegisterH = (unsigned char *) 0xC5;
baudRateRegisterL = (unsigned char *) 0xC4;
*uControlandStatusRegisterA &= 0xE0;
*uControlandStatusRegisterA |= 0x40;
*uControlandStatusRegisterB &= 0xBB;
*uControlandStatusRegisterB |= 0xB8;
*uControlandStatusRegisterC = 0x0E;
*baudRateRegisterH &= 0xF0;
*baudRateRegisterL = 0x08;
portDDRD = (unsigned char *) 0x2A;
portD = (unsigned char *) 0x2B;
*portDDRD = 0xFC;
void loop ()
unsigned char dataByte ;
if ( ReceivedBytes () > 0)
dataByte = GetNextReceivedByte ();
switch (dataByte)
case '0':
TransmitString("Zero\n", 5);
case '1':
TransmitString("One\n", 4);
break ;
case '2':
TransmitString("Two\n", 4);
break ;
case '3':
TransmitString("Three\n", 6);
break ;
case '4':
TransmitString("Four\n", 5);
break ;
case '5':
TransmitString("Five\n", 5);
break ;
case '6':
TransmitString("Six\n", 4);
break ;
case '7':
TransmitString("Seven\n", 6);
break ;
case '8':
TransmitString("Eight\n", 6);
break ;
case '9':
TransmitString("Nine\n", 5);
break ;
default :
TransmitString("Default\n", 8);
break ;
unsigned char ReceivedBytes (void )
unsigned char *statusRegister ;
unsigned char shadow ;
unsigned char receiveHead ;
unsigned char receivedBytes = 0;
statusRegister = SREG_ADDR;
shadow = *statusRegister;
statusRegister &= ~SREG_GLOBAL_INT_ENABLE;
/ Turn off global interrupts here. */
receiveHead = g_receiveHead;
/* Restore global interrupts here. */
if (( shadow & SREG_GLOBAL_INT_ENABLE ) == SREG_GLOBAL_INT_ENABLE )
*statusRegister |= SREG_GLOBAL_INT_ENABLE;
if ( receiveHead > g_receiveTail )
receivedBytes = receiveHead - g_receiveTail;
else if ( receiveHead < g_receiveTail )
/* Check the case that the head has circled around but the tail
hasn ’t. */
receivedBytes = receiveHead + (USART_RECEIVE_BUFFER_SIZE - g_receiveTail);
return receivedBytes ;
unsigned char GetNextReceivedByte (void )
unsigned char receivedByte = 0;
receivedByte = g_receiveBuffer[g_receiveTail ++];
if ( g_receiveTail >= USART_RECEIVE_BUFFER_SIZE )
g_receiveTail = 0;
return receivedByte ;
ISR(USART_RX_vect)
*portD = 0x80;
unsigned char * portUSARTDataRegister ;
unsigned char * portUSARTControlAndStatusRegisterA ;
portUSARTDataRegister = UDR0_ADDR;
portUSARTControlAndStatusRegisterA = UCSR0A_ADDR;
while (((* portUSARTControlAndStatusRegisterA ) & UCSR0A_RXC_MASK ) != UCSR0A_RXC_EMPTY)
g_receiveBuffer[g_receiveHead ++] = *portUSARTDataRegister;
if ( g_receiveHead >= USART_RECEIVE_BUFFER_SIZE )
g_receiveHead = 0;
void TransmitString (const char *bytes , unsigned char numberOfBytes )
unsigned char * portUSARTControlAndStatusRegisterB ;
unsigned char i;
for (i = 0; i < numberOfBytes ; i++)
g_transmitBuffer [ g_transmitHead ++] = (unsigned char ) bytes ;
if ( g_transmitHead >= USART_TRANSMIT_BUFFER_SIZE )*
g_transmitHead = 0;*
_ /* Turn on the TX interrupt. */_
portUSARTControlAndStatusRegisterB = UCSR0B_ADDR;*
_ shadow = *portUSARTControlAndStatusRegisterB;_
shadow &= ~( UCSR0B_TXEN_MASK);*
shadow |= (UCSR0B_TXEN_ON);*
_ *portUSARTControlAndStatusRegisterB = shadow;_
ISR(USART_UDRE_vect)
_ unsigned char * portUSARTDataRegister ;_
_ unsigned char * portUSARTControlAndStatusRegisterB ;_
unsigned char shadow ;*
portUSARTDataRegister = UDR0_ADDR;*
if ( g_transmitHead != g_transmitTail )*
*portUSARTDataRegister = g_transmitBuffer[g_transmitTail ++];
if ( g_transmitTail >= USART_TRANSMIT_BUFFER_SIZE )*
g_transmitTail = 0;*
else*
shadow |= (UCSR0B_TXEN_OFF);*
