Im having a very hard time understanding serial communication... hopefully one of you can help me out.
I need to write a function to check communication between processing and my arduino via serial.
I am sending the a stream of character "A" from processing to arduino
when Arduino sees an 'A' then it sends a character 'B' back to processing
when processing sees that 'B' then it sends the character 'C' back to arduino
this is done for this reason:
stream of A's sent 1/4 sec apart to allow arduino time in case its not yet ready to receive
once the arduino is receiving data it gets that A and replies with a B to let processing know its online and receiving
processing reads that B then sends arduino a C to let it know it can now proceed to the void loop() function and start streaming the actual sensor data
BTW im using an arduino micro so like Leonardo it uses Serial and Serial1....Serial1 is used to receive data from elsewhere but doesn't apply to this section of the sketch. likewise on the processing end there are two serial connections established but only myport is used to communicate to this arduino so myport2 is not applicable either...the robot() class is used elsewhere also but since it has a delay feature I dropped it into this part of the sketch to only send data every 1/4 second so it doesn't fill up the buffer too fast waiting for arduino to respond....If besides the solution you have a better approach to achieve this please let me know... I am making this stuff up as I go ad don't really know the most efficient way to accomplish this....thnkx
My programs look like this:
Arduino:
char ch;
int R;
int L;
int comFlag=0; //0=waiting for initial request to connect from PC
//1= request received...sending confirmation to PC
//2=confirmation acknowledged by PC ready to proceed into main loop()
Serial.begin(19200);
Serial1.begin(19200);
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
//ESTABLISH COMMUNICATION LINK WITH PC
while(comFlag!=2){
if (Serial.available()) {// wait for data from pc
ch=(char)Serial.read(); //if data is available read it
if(ch=='A' && comFlag==0){
Serial.println("B");//Send 'A' character back to pc to acknowledge that it received the data
comFlag=1;//flag to let us know that we are ready for stage two of connection verification process
if (ch=='C' && comFlag==1){ //check to see if data in = 'C'
comFlag=2;
void loop() // run over and over
The processing end looks like this:
import java.awt.Robot;
import java.awt.AWTException;
import java.awt.event.InputEvent;
import processing.serial.*;
import guicomponents.*;
Serial myPort;
Serial myPort2;
Robot robby;
char message;
size(267, 366);
try
robby = new Robot();
catch (AWTException e)
println("Robot class not supported by your system!");
exit();
println(Serial.list());
println(" Connecting to -> " + Serial.list()[portIndex]);
myPort = new Serial(this, Serial.list()[portIndex], 19200);
String portName = Serial.list()[1];
myPort2 = new Serial(this, portName, 9600);
robby.mouseMove(xx, yy);
String[] files;
//ESTABLISH SRIAL COMMUNICATION WITH HEADSET
while (message!='B') {//Write 'A' to serial port until a reply is received
int message = myPort.read();
println(message);
myPort.write('A');
println("Waiting for connection");
robby.delay(25);
myPort.write('C');
println("CONNECTION ESTABLISHED!!!");
//robby.delay(1000);
void draw(){
