Hi guys. First up, my apologies - this is really a basic electronics question rather than an Arduino one, but I figured you guys would definitely point me in the right direction.
I'm building a DRS (drag reduction system) for a racecar. It moves one plane of a multi-plane wing through a 60 degree angle. The movement needs to be quick (sub-0.5s) and needs to hold a force of around 30kg in its "up" position. Ideally, I want it triggered between the two positions via what are effectively two momentary switches (12v feeds from other on-board switches).
Having looked at pneumatic and hydraulic options, I'm now looked at electric actuation due to simplicity and weight considerations. My electronics skills, however are fairly rudimentary.
I'm proposing to use a pair of these:
https://www.amazon.co.uk/ZOSKAY-Torque-Crawler-Compatible-SAVOX-0236/dp/B0BTZ5FTXX
Now, as it's just a simple 2-position movement, I was hoping to avoid the complication of anything that needs full coding and instead just use a simple movement module like this:
https://kitronik.co.uk/products/2177-kitronik-movement-module-simple-servo-controller
However, 5v isn't going to cut it and fag packet sums say it's going to be potentially pulling 10A+ at full load.
So I'm thinking some NPN transistors wired in parallel plus a resistor to make a low side switch (this is about the limit of my electronics knowledge!)
So, questions:
Am I reinventing the wheel? Is there just an off-the-shelf module that will do this job (and likely be more reliable that my home-brew lash up)? Is this what a MOSFET switch/driver is?
Generally, am I on the right lines, and will these components suitably rated to work together?
Any links to specific components/products would be most appreciated too!
Thanks in advance for any help you can offer.
