Simple servo question
Hi, I'm very new to programming and using Arduino, and I'm trying to send a servo to a specific position. I wrote the code that will do this, but my servo hums at almost any position other than 180 degrees. Why? For example, in my code I replace "180" with "45" and the servo hums but does travel to the correct spot. How do I stop applying a signal to the servo to save power and eliminate the hum? Thanks!
Here is my simple code:
#include <Servo.h>
Servo myservo;    // create servo object to control a servo
int pos = 180;    // variable to store the servo position
  myservo.attach(9);  // attaches the servo on pin 9 to the servo object
  myservo.write(pos);     // tell the servo to go to the position defined
  delay(15);              // wait for the servo to get there.
Call "detach", but be aware that the servo may not hold position if it is loaded.
