I know this is a simple question, but I am a 75 year old guy (who used to be a pretty good FORTRAN programmer) who is having trouble with C++ (Arduino).
So .... I have a variable called hour and is declared as a byte type. All I want to do is add 1 to the value in hour.
I have tried hour = hour + 1 . It doesn't work. Where am I going wrong?
schuh8:
Most likely problem: you have put the statement outside any function.
In a fortran program, execution starts at the top of the file, which can call other functions, but doesn't need to.
In a C program or arduino sketch, all executable statements must be inside some function like main() {} or Setup() {}
(some C statements can appear outside of a function, but they're nominally "definition" statements rather than executable statements.)
// GLOBAL VARIABLES
// ... INITIIALIZED TO ZERO BY DEFAULT ...
// ... UNLESS SPECIFICALLY OTHERWISE ...
int hour;
// ARDUINO - REQUIRED
// LOCAL VARIABLES MUST BE SPECIFICALLY INITIALIZED
// ... OR WILL CONTAIN WHATEVER GARBAGE WAS ...
// ... AT THEIR ADDRESS ON THE STACK ...
int hour = 0;
// initialize serial port to 9600 baud
Serial.println(hour);
hour = hour + 1;
lloydean dont you feel it would have been better to wait for schuh8's response on this one considering he is a total newbie to C, C++ programming. Moreover what purpose would a confusing(for a newbie) example code ,containing a global and a local variable of same name and without proper indentation with a different data type than one mentioned in the problem, serve.
Chaitanya1:
What as silly question.
If I felt it would've been "better" to wait I would've waited but I "felt" it would be better to show a working example then to make him guess.
I, very much on purpose, show both local and global variables; that the two can have the same name but not be the same values. I comment on the differences in initializing global vs local variables.
"... same name and without proper indentation with a different data type than one mentioned in the problem, serve."
But these confuse me.
What are you going on about with "proper" indentation?
A different "type" than the one mentioned? He mentions no type so how can I be using something different?
A 'byte' is such a generic thing and I NEVER use it as a type as it is ambiguous when doing cross platform programming sometimes signed and others unsigned.
schuh8:
This works fine. At a guess, you are initializing the value of hour to zero in your loop().
schuh8:
75 years or not, you get a much better answer, and save a lot of guessing, by posting all your code.
