So first off, digital pins in the arduino when set on output will output 5 volts correct? arduino.cc says each i/o will give off 40 mA dc current (correct me if im wrong cause im entirely inexperienced with electronics).
So if i add for example a 1k resistor into the mix then what is the current now. Im not sure cause i know the formula V = I *R, but arent the current and voltage independent-fixed-values? or is the voltage 5v and is there an internal resistance in the arduino of .. 125 ohms cause 5/125 = 0.040A. thus would i just add on the 1k to that resistance (since its obviously in series) to make it 1125 and my result is 5/ 1125 = 0.004A.
What im trying to do is just set up a 2n2222A transistor (not rocket science, i know) but i read that i should aim for 0.6-0.7 volts into it. So i could do it by trial and error and a volt meter, but id just like to know how to do the calculation to know what resistance would be appropriate.
Any help would be sweeeeeeeeeeeeeeeeeeeet.
