Simple Sine wave generator
simple sine wave generator - code modified for improvement from http://forum.arduino.cc/index.php?topic=8563.0
generate sine wave using PWM output.
low voltage positive sinewave signal (0~5V)
adjustable sinewave frequency, offset and amplitude.
code:
//code modified for improvement from http://forum.arduino.cc/index.php?topic=8563.0
//connect pin 9 -> 10k Ohm + (series with)100nF ceramic cap -> GND, tap the sinewave signal from the point at between the resistor and cap.
float wav1[3];//0 frequency, 1 unscaled amplitude, 2 is final amplitude
int average;
const int Pin = 9;
float time;
float percentage;
float templitude;
float offset = 2.5; // default value 2.5 volt as operating range voltage is 0~5V
float minOutputScale = 0.0;
float maxOutputScale = 5.0;
const int resolution = 1; //this determines the update speed. A lower number means a higher refresh rate.
const float pi = 3.14159;
  wav1[0] = 50; //frequency of the sine wave
  wav1[1] = 2.5; // 0V - 2.5V amplitude (Max amplitude + offset) value must not exceed the "maxOutputScale"
  TCCR1B = TCCR1B & 0b11111000 | 1;//set timer 1B (pin 9) to 31250khz
  pinMode(Pin, OUTPUT);
  //Serial.begin(115200);//this is for debugging
  time = micros()% 1000000;
  percentage = time / 1000000;
  templitude = sin(((percentage) * wav1[0]) * 2 * pi);
  wav1[2] = (templitude * wav1[1]) + offset; //shift the origin of sinewave with offset.
  average = mapf(wav1[2],minOutputScale,maxOutputScale,0,255);
  analogWrite(9, average);//set output "voltage"
  delayMicroseconds(resolution);//this is to give the micro time to set the "voltage"
// function to map float number with integer scale - courtesy of other developers.
long mapf(float x, float in_min, float in_max, long out_min, long out_max)
  return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
sinewave.ino (1.58 KB)
add clipping when output is out of range.
code (portion added):
// clip the max and min output
if (wav1[2]>maxOutputScale){
wav1[2] = maxOutputScale;
else if (wav1[2]<minOutputScale){
wav1[2] = minOutputScale;
else{
//do nothing
analogWrite(9, average);//set output “voltage”
delayMicroseconds(resolution);//this is to give the micro time to set the “voltage”
