Hi everyone, so I just have a school project where I need to measure the acceleration of a wooden "building" that I made, I'll do it with the BMA180 accelerometer, but considering that I'm completely new to arduino, I really need help !
I just need a simple sketch that would give me the values of acceleration, and how to wire it. Thanks in advance!
Welcome to the forum
It took me about 10 seconds to find this
https://www.electrodragon.com/bma180-three-axis-accelerometer-demo-test-with-arduino/
Hi @UKHeliBob,
I guess chaima_1 will not get happy with the sketch you linked ... The person who uploaded it to the electrodragon page
- is using the old Wire.send() and Wire.receive() functions (rather than Wire.write() and Wire.read())
- did not #include <Wire.h> and
- created some nice "code" by "C++ to HTML" like this
data += Wire.receive() < ; < ; 8;
which can be understood as
data += Wire.receive() << 8;
and (also nice
Wire.send(data & ; 0x0F); // low pass filter to 10 Hz
which I understand as
Wire.write(data & 0x0F);
This would be the corrected sketch (at least it compiles); would you mind to look over it?
#include <Wire.h>
Wire.begin();
Serial.println("Demo started, initializing sensors");
AccelerometerInit();
// GyroInit();
Serial.println("Sensors have been initialized");
void AccelerometerInit()
Wire.beginTransmission(0x40); // address of the accelerometer
// reset the accelerometer
Wire.write(0x10);
Wire.write(0xB6);
Wire.endTransmission();
delay(10);
// low pass filter, range settings
Wire.write(0x0D);
Wire.write(0x10);
Wire.write(0x20); // read from here
Wire.requestFrom(0x40, 1);
byte data = Wire.read();
Wire.write(0x20);
Wire.write(data & 0x0F); // low pass filter to 10 Hz
Wire.write(0x35); // read from here
data = Wire.read();
Wire.write(0x35);
Wire.write((data & 0xF1) | 0x04); // range +/- 2g
void AccelerometerRead()
Wire.write(0x02); // set read pointer to data
Wire.requestFrom(0x40, 6);
// read in the 3 axis data, each one is 16 bits
// print the data to terminal
Serial.print("Accelerometer: X = ");
short data = Wire.read();
data += Wire.read() << 8;
Serial.print(data);
Serial.print(" , Y = ");
data = Wire.read();
Serial.print(data);
Serial.print(" , Z = ");
data = Wire.read();
Serial.print(data);
/*void GyroInit()
Wire.beginTransmission(0x69); // address of the gyro
// reset the gyro
Wire.write(0x3E);
Wire.write(0x80);
// low pass filter 10 Hz
Wire.write(0x16);
Wire.write(0x1D);
// use internal oscillator
Wire.write(0x3E);
Wire.write(0x01);
void GyroRead()
Wire.write(0x1D); // set read pointer
Wire.requestFrom(0x69, 6);
// read in 3 axis of data, 16 bits each, print to terminal
short data = Wire.read() << 8;
data += Wire.read();
Serial.print("Gyro: X = ");
Serial.print(data);
Serial.print(data);
Serial.print(data);
AccelerometerRead();
// GyroRead();
delay(500); // slow down output
He/she can be as unhappy as they like. My main point was that I found information on the subject in no time at all.
No offence, your approach is really appreciated! The skills in using Google are as (or sometimes maybe even more) helpful than programming skills ... At least Google skills help in much more situations ![]()
P.S.: Just looked up the page a second time and went all the way down the comments just to find somebody had made the same changes already in Oct 2012 (only missed to include Wire.h) ... Ok, re-invention of the wheel appears every day ...
It's déjà vu all over again
Hi
I searched too and found this, but I had some doubts, so I thought I'd better ask some well experienced people before
It would have been a good idea to mention that in your original post
Thank you so much!
Does it work? That's the question ...
P.S.: And - as @UKHeliBob mentioned - giving some more information about what you tried, what did not work etc. will do several things:
- It shows that you have already made your own efforts to find a solution
- It may save other people's time to google themselves
- It allows to focus on "the problem" rather than finding out what the problem is
Most of the tasks here can/could be solved by
- searching for the same or similar issue on the net
- gaining some basic knowledge in C++, microcontrollers and electronics
